Super charger questions
Old Nov 14, 2005 | 10:47 PM
04Roadster's Avatar
Question Super charger questions
1. How much boost does the SRT blower produce?
2. Is the PCU in the SRT different than the normal PCU? (tuning)
3. Does the SRT have the same injectors as normal motor?
4. Has anyone look at a procharger?
I was looking at a procharger and there is plenty of room under the hood, might have to relocate the alt. A couple of brackets > and that would be a done deal. Any help would be great.
Thanks > Pete
Old Nov 14, 2005 | 11:22 PM
respdoc's Avatar
Default Re: Super charger questions
I was looking at a procharger and there is planty of room under the hood, might have to relocate the alt. A couple of brackets > and that would be a done deal. Any help would be great.
Thanks > Pete
PCU? ...you mean ECU...
Either way do a search for all the details to your above questions...short answer: no, it won't work properly...
Old Nov 15, 2005 | 01:54 AM
Black SRT's Avatar
I don't think we have found out if the ECUs can be swapped out, but it would probably only work safely with the AMG S/C. A procharger not make the boost the same as the AMG S/C. I'm still thinking that a turbo will be the cheapest rout.
Old Nov 15, 2005 | 08:42 AM
SRT6_Roadster's Avatar
The SRT is running ~1 bar (14.7 psi) of boost stock.
Yes, the tuning is different on the SRT as the other crossfires.
I am pretty positive the SRT injectors are larger.
No, you can not just swap the ECU's. My understanding is that the are VIN coded from the factory. I believe the dealer can override this with the help of the factory though.
Old Nov 15, 2005 | 06:37 PM
x'ed's Avatar
its crazy, over two years and no one has supercharged the na crossfire yet. people even supercharge alero and crap. hope this one works out.
Old Nov 15, 2005 | 07:57 PM
respdoc's Avatar
Actually for once, you make a great point...so, why do you think this is?
Old Nov 15, 2005 | 08:56 PM
x'ed's Avatar
because people with crossfires aren't into modding their cars. don't even start the "motor cant handle it crap". if the 11.6:1 compression it can handle the boost, so can a crossfire.
Old Nov 15, 2005 | 09:15 PM
respdoc's Avatar
The initial boost factor is not the problem...what is effects long-term durability and getting all the parts to play together nice. AMG, just like any other business, minimizes production costs so most of the beefier parts they use in the 3.2 liter block have a purpose for being there...
Old Nov 15, 2005 | 09:37 PM
x'ed's Avatar
almost every car on the market can be supercharged. im sure not everyone is looking to get 200k miles outta their crossfire, for me it will just be a daily driver once i get a sky redline. i know that toyota claims that there is only a 2 percent decrease in engine life with their trd superchargers equipped, and their motors have not beefier parts to handle the power. mercedes builds some of the strongest motors out there.
Old Nov 15, 2005 | 09:57 PM
bobs's Avatar
The compression ratio is also 9.0:1 vs 10.0:1 for the N/A car. Running almost 15 psi of boost on a 10.0:1 engine is a recipe for melted parts.
For comparison, my 'Lude has 10.0:1 compression and the blower is running 8 psi at max boost. So that would pretty much mean that the SRT-6 blower & PCM software are not simply a bolt-on mod. You're either going to have to lower the compression ($$$) or slow that blower down by about half.
Bob...
Old Nov 15, 2005 | 10:21 PM
04Roadster's Avatar
The charger is making 14 psi of boost > WOW!!! I figured it made like 5-6 lbs of boost. What style blower is the AMG? Any pics?
What web site sells these saskins intakes, or is that even an intake?
Where are you all getting the performance chips from? Can you not program the ECU with a programmer, or do you have to get a chip?
I would do a search > but enjoy conversation and interaction!
Old Nov 15, 2005 | 10:24 PM
04Roadster's Avatar
Oh yea > I didn't mean "swap" the ECU > I was just wondering if the tuning was any different. There are lots of cars that can handle no injector upgrade or tuning with the addition of a blower. Of course the boost would have to be minimal...A blower will not lower the life of a motor > that would be a foot that would do that...lol
Old Nov 15, 2005 | 10:51 PM
x'ed's Avatar
the procharger doesn't boost a bar, the srt does. procharger is probably 6 or 8 psi.
Old Nov 15, 2005 | 10:57 PM
x'ed's Avatar
just checked, boosts 7.
Old Nov 15, 2005 | 11:21 PM
stallion8797's Avatar
Banned
This may be a stupid question, but is the procharger a centrifugal blower?
Old Nov 15, 2005 | 11:40 PM
x'ed's Avatar
Thanks > Pete
which system would you use? is there a generic one or would you use one from another car...
Old Nov 16, 2005 | 12:19 AM
respdoc's Avatar
It's to your benefit to do a search if your serious about supercharging the base Crossfire but I'm getting the idea your not given your choice of a procharger (their website shows no kits for a Mercedes or even a Chrysler product). So besides just the hunk of metal with a turbine fan inside of it, every other piece of hardware will have to be custom-fabbed, and that's just the beginning...
Old Nov 16, 2005 | 12:30 AM
x'ed's Avatar
ha...do you have alot of supercharger experience? because there isn't a whole lot that would have to be done.
Old Nov 16, 2005 | 12:31 AM
x'ed's Avatar
as far as custom fab stuff i mean...ecu stuff may be different.
Old Nov 16, 2005 | 01:07 AM
respdoc's Avatar
Hmm..first you would have to make a custom intake system, brackets, (def. add some sort of intercooler or the heat will kill most of the h.p. your trying to make), and few belts along with a place to mount all of this. After that you can move onto minor issues like the car wanting to run lean, etc.
Anything is possible with enough time and money and patience but.
