SRT6 Idle/Throttle Issue - Seeking advice
Old May 15, 2020 | 05:16 PM
s.mpr's Avatar
Default SRT6 Idle/Throttle Issue - Seeking advice
Hello All - I have a 2005 SRT6 Roadster with the following modifications: Larger crank pulley (ASP), NeedsWings single intake, Eurocharged tune, low temp thermostat, NeedsWings catch can and pulley saver kit. It is a fair weather car that has just under 13,000 miles on it. I am having a high and rough idle issue that is throwing me for a loop. Have left the battery disconnected for much time, performed many throttle body resets, etc. And the issue comes about whether the engine is hot or cold.
It started with a pull when stopped, say, at a stop light, where the throttle would go up to 1,500 or so. I replaced the intake manifold gaskets (with NeedsWings), and then it jumped to 1,500-3,000 RPM when started. I then replaced the CPS, though issue remained. Just replaced the throttle body with a new Bosch unit and issue remains.
Curious what thoughts may be. No problem going back to stock if needed. Other than a new intercooler pump a few years ago, there have been no other issues.
Thank you and I hope everyone is doing well during this time.
Old May 15, 2020 | 06:06 PM
Default Re: SRT6 Idle/Throttle Issue - Seeking advice
To me, it sounds like a VAC leak. I would channel my energies on looking for a vacuum leak. Good luck!
Old May 15, 2020 | 06:31 PM
NeedsWings's Avatar
check the throttle body spacer/gasket, the rubber may have degraded and cracked. if that looks good continue to look for a vacuum leak, could also be the charcoal canister or brake booster line from the supercharger inlet.
Old May 16, 2020 | 01:02 PM
s.mpr's Avatar
Thank you for the replies. I ordered a stethoscope and will report back what is found.
Old May 17, 2020 | 12:57 PM
s.mpr's Avatar
Is there a trick to getting the bottom bolt out of the throttle body spacer? I have a replacement gasket. Also, seems I can hear a vacuum leak somewhere on passenger side of engine near back of engine. Will get closer when stethoscope comes in. Thanks.
Old May 21, 2020 | 05:35 PM
s.mpr's Avatar
Update: Stethoscope in and not sure it is helping. I did notice that the exhaust pipes behind the engine, right where the O2 sensors are, glow red hot when running and bouncing RPMs during idle. Now wondering if perhaps O2 sensors or catalytic converter. Anyone seen this before?
Thank you.
Old May 22, 2020 | 12:54 AM
UrbanE's Avatar
Thank you.
Are you getting any codes?
Old May 22, 2020 | 03:51 AM
First, I am not an expert. That said, you MIGHT have a failed Cat. Posting the CODES might help.
Old May 22, 2020 | 08:03 AM
s.mpr's Avatar
Thanks. CEL comes on after a bit. Code reads: P0507, 'Idle Air Control System RPM Higher Than Expected.'
Old May 22, 2020 | 10:17 AM
NeedsWings's Avatar
Thank you.
i would say either your timing is off or your cats are clogged. are both sides glowing? if so check your catback, there was a guy that had a rodent filling up his muffler with dog food once.
Old May 22, 2020 | 10:19 AM
s.mpr's Avatar
Thanks. Both sides glowing red hot. Catback looks clear and seems to have normal-ish flow.
Old May 23, 2020 | 04:13 AM
philosophico's Avatar
You should never see anything glowing red hot unless its running at redline. What is glowing red hot?
Old May 23, 2020 | 08:15 AM
s.mpr's Avatar
Exhaust behind engine, where O2 sensors are. These are glowing hot when at bouncing/rough idle. Thanks.
Old May 23, 2020 | 08:32 AM
Strange... I am wondering if your exhaust check (thinking partial plugged cats) is misleading since it seems the cats are glowing like this. Maybe way too much unburned fuel is present at cats?
A lot more information (like a good code reader made to tap into the MB codes and test data) looks like a must
Old Jun 16, 2020 | 11:27 AM
s.mpr's Avatar
Update - I will get the car over to a mechanic in the coming weeks and will report back. Thanks All.
Old Jun 16, 2020 | 01:44 PM
zip439's Avatar
There is a vacuum line under the battery. It deteriorates because of battery acid. It has been know to cause rough idle.
Old Jun 16, 2020 | 02:38 PM
velociabstract's Avatar
You most likely have a LARGE leak. The supercharger outlet has a short rubber hose to the Y pipe. On my car one of the clamps failed and caused the hose to partially come off. My car ran at 3000 rpm at idle until I found the broken clamp and replaced it. Take your time and look for something unusual out of place like my broken clamp.
Les
Old Jul 22, 2020 | 08:39 AM
s.mpr's Avatar
Update: Hauled the car to a recommended shop a couple of hours away. The issue was the intake manifold gaskets. Picked up the car last night and runs great. Just wanted to close this out. Now on to the rear window adhesion issue.
Thanks.
15Spokes
Sep 16, 2018 12:52 PM
blazodan
Aug 27, 2018 08:40 AM
Crossed Out
Feb 9, 2015 07:58 PM
jayded6
Oct 29, 2010 09:51 PM
Aerodmb
Dec 12, 2006 02:12 PM
