Catch can install
Old Aug 9, 2020 | 12:54 PM
Default Catch can install
Has anyone installed a catch can on an SRT-6? The tee seems different than the one in needwings instructions must be NA? Also the tee for my throttle body is in bad shape. Does anyone have a part number and source for a new one? Any part numbers for the throttle body gasket? Might as well do it right.
Thanks
Old Aug 9, 2020 | 01:32 PM
Default Re: Catch can install
Thanks
You can see the NA and SRT instructions in my thread below ( they are near the bottom under the Needswings heading) and you can compare them to what you have.
Old Aug 9, 2020 | 01:45 PM
Thanks again sir you are always to the rescue. Any thought on replacement Tees? Over the years the rubber goes bad.
Old Aug 9, 2020 | 05:52 PM
Sorry I cannot help. Put a plea out on the forum.
Old Aug 9, 2020 | 07:25 PM
4 bucks cheap cheap ....
https://www.fcpeuro.com/products/mer...tor-1120180209
Not sure it fits the SRT6 though.
Old Aug 10, 2020 | 03:26 PM
Doesn't look like it but thanks for trying.
Old Aug 10, 2020 | 07:32 PM
Like George suggested, although this didn't fit your needs there are ALWAYS less expensive alternatives! Good luck in your searches!
Old Aug 10, 2020 | 09:13 PM
Petersrt6's Avatar
I installed this catch can earlier this year.
located in front of oil dip stick. I made a bracket which mounts on to the water pump flange.
I combined both breather hoses into one hose then to inlet on the can.
The return hose connects to the venturi port on the throttle body. I blank off the other side of the return port.
https://photos.app.goo.gl/QweX1Na8eJeGGZUDA
Old Aug 12, 2020 | 06:17 PM
philosophico's Avatar
You can send needswings an email and see if he has a spare for sell. He's bailed me out on obscure srt-6 only plastic/rubber bits before.
SRT6_Roadster
Jan 3, 2012 07:19 AM
mjgroves
19
Mar 10, 2011 08:17 PM
MisterTaz
May 17, 2010 09:06 AM
TVT_DESIGN
Feb 22, 2009 08:59 PM
amx1397
Jan 14, 2009 07:27 PM
