Supercharger oil + 0W40 engine oil.
Old Sep 23, 2021 | 09:55 AM
ku95's Avatar
Default Supercharger oil + 0W40 engine oil.
Hello,
What will happen when 1quart of jet oil is mixed with engine oil?
Old Sep 23, 2021 | 09:59 AM
Default Re: Supercharger oil + 0W40 engine oil.
Why would you?
Old Sep 23, 2021 | 10:04 AM
ku95's Avatar
Originally Posted by ZERACER
Why would you?
Because I have 1 quart of jet oil for spare coming exp. date.
Just curious...^^
Old Sep 23, 2021 | 10:58 AM
May not be compatible with synthetic? Might not mix. I also do not know the viscosity of the jet oil?
Old Sep 23, 2021 | 12:24 PM
nemiro's Avatar
I wouldn't sweat the expiration date, when used for the supercharger. That date is likely more pertinent for use in FAA regulated aircraft. I certainly wouldn't use it, nor waste it, by mixing it in my engine oil.
Old Sep 23, 2021 | 05:53 PM
Just curious...^^
For the cost of a quart of that stuff, you are going to risk your engine?
I'm wondering what other questionable life choices you have made....
Old Sep 24, 2021 | 04:54 PM
copperfieldkid's Avatar
Exclamation Re: Supercharger oil + 0W40 engine oil.
I have mixed/used 100 octane aviation fuel (NOT Jet fuel) in vehicles and it's fine for high performance, costly tho. However I would NOT mix/use Mobil Jet oil in a car. Here is an explanation of applications and usage:
Applications
Mobil Jet Oil 254 is recommended for aircraft gas turbine engines of the turbo-jet, turbo-fan, turbo-prop, and turbo-shaft (helicopter) types used in commercial and military service. It is also suitable for aircraft-type gas turbine engines used in industrial or marine applications.Mobil Jet Oil 254 is approved against the High Thermal Stability (HTS) classification of U.S. Military Specification MIL-PRF-23699. It is also compatible with other synthetic gas turbine lubricants meeting MIL-PRF-23699. However, mixing with other products is not recommended because the blend would result in some loss of the superior performance characteristics of Mobil Jet Oil 254.Mobil Jet Oil 254 is completely compatible with all metals used in gas turbine construction, as well as with F Rubber (Viton A), H Rubber (Buna N), and other commonly used seal materials.
(All of the builder approvals are aircraft engine builders) Clearly this product is for aviation use only (Turbine engines)
Old Sep 24, 2021 | 09:38 PM
nemiro's Avatar
...and superchargers.
Old Sep 24, 2021 | 11:52 PM
You are correct! There is oil in the SLK32 supercharger and it is different and separate from the engine oil. Mobil Jet Oil is an approved supercharger oil for the SLK32.
The original question was the mixing of engine oil and Jet oil.
ku95 "Hello,
What will happen when 1quart of jet oil is mixed with engine oil? "
Old Sep 27, 2021 | 10:54 AM
ku95's Avatar
I found interesting video in Youtube.
I was surprised that it was already tested.
Anyway, jet oil keeps it's own property more than car engine oil at severe condition, but it seems that it does not make benefits in car engine.
Old Sep 27, 2021 | 12:32 PM
Very informative, and the music wasn't bad either! Reminiscent of my Physics and Chemistry classes. (Bottom line: don't use Jet Oil in your vehicle)
Romad
Nov 2, 2025 07:57 PM
former NXMX5
16
Jul 16, 2021 09:48 PM
RoomSeven14
15
May 14, 2021 08:29 AM
DZL
Apr 5, 2012 08:34 AM
70GT6
Jun 29, 2010 12:14 PM
