Supercharger snout breathing hole
Old Feb 20, 2024 | 10:39 AM
ku95's Avatar
Default Supercharger snout breathing hole
Finally I recover breathing hole of s/c snout.
Most cases of s/c oil leakage from oil seal caused by clogging breathing hole.
Please refer to YouTube shorts lowest.
Thanks.
Old Feb 21, 2024 | 11:42 PM
nickwe21's Avatar
Default Re: Supercharger snout breathing hole
Habe never really heard of this being an issue...did someone overfill the supercharger oil? Or use a supercharger screw when replacing pulley that isn't hollow like the OEM? I don't see how that should get clogged up..
Old Feb 22, 2024 | 10:27 AM
ku95's Avatar
I have 5 s/c for various reasons for test (magnetic, beaing, seal, oil leakage and so on...)
Just found yesterday one breathing and pushed air to other clogged snout then it gradually breathing.
Old Feb 22, 2024 | 11:27 AM
nickwe21's Avatar
Originally Posted by ku95
I have 5 s/c for various reason for test (magnetic, beaing, seal, oil leakage and so on...)
Just found yesterday one breathing and pushed air to other snout then it gradually breathing.
Just out of curiosity. What are you trying to achieve/test?
My guess in this case they either used the wrong oil (viscosity) or overfilled, which leads the S/C snout to push the overfilled oil out through the snout and ultimately the hollow screw. But that would have to be a lot of overfilled oil to gum up this relatively large snout. I just don't see how it became clogged unless the wrong pulley screw was used (one that wasn't hollow), the wrong oil or just massive overfilling.
Never seen that issue on any of our pages through the years. What were the symptoms of this vehicle?
Old Feb 23, 2024 | 07:53 AM
ku95's Avatar
The begining was s/c oil leakage.
I replaced oil seal with additional spring ring but it leaks.
Then replaced needle bearing at snout but faced other problem.(It has many stories)
Anyway I agree with you.
I have always used hollow bolt and leakage occured 2-years later after replacing s/c oil with jet oil.
Snout breathing was found by accident.
Only one is easily breathing and it may be original condition, Others were no breathing but now very hard breathing after air pressure and chemicals.
srtmodder
Jul 29, 2015 05:12 PM
Zeph94
Jul 6, 2015 02:58 PM
MadisonCrossfire
Mar 5, 2015 12:27 PM
Vad El'
Dec 5, 2007 08:44 PM
sambo13
Dec 31, 2003 06:34 PM
