Eurocharged Tunes
Old Jan 19, 2026 | 05:53 PM
4drturbo's Avatar
Default Eurocharged Tunes
The SRT-6 I am going to be checking out in a week or so I found out has a Eurocharged tune from the prior owner. Anyone running their base tune?? Looks like it has been on the car for over 10 years and roughly 8k miles. I take it they are reliable good tunes? Couldn't find much info on the SRT-6 section about it.
Old Jan 19, 2026 | 07:29 PM
Default Re: Eurocharged Tunes
Eurocharged is well known here and many have the Eurocharged tunes with improved performance and HP
I got one all the way back in 2009
https://www.eurocharged.com/tuning/c...72/773-3.2srt6
Old Jan 20, 2026 | 01:40 AM
gblack32's Avatar
They are fine. Had mine for probably 8-9 years
Old Feb 12, 2026 | 05:01 PM
HumanMode's Avatar
Mine came in 2024 with a Eurocharge tune which was apparently acquired in about 2009 after pulleys were added. It's been running well. I've added a SCAI and done the Needs Wings waldig/pulley saver upgrade, and all sweet. Note though that when I got the car there were some codes being thrown. My mechanic had an awful time trying to sort them out, and the ECU tune confused him. We explored removing the tune but his favourite ECU tuner didn't want to touch it without a copy of the original file. I was able to contact the owner who did the tune (NZ is a small place) but he didn't have the file, and Eurocharge never got back to me. I took the car to a good auto electrician who replaced various sensors, and killed the codes using the correct OBD scanner. There was no need to do anything about the ECU tune. Apart from the lesson if using a knowledgeable mechanic and getting a OBD scanner for yourself, the other lesson is that tunes are good and best left once done?
Old Mar 9, 2026 | 06:02 PM
nickwe21's Avatar
My car came w/EC tune. I still have the file. Then I got a V-Tech Georgia (the country) tune. They are well known on MB forums and Facebook groups. On my other vehicle I have the Mercedes Swap Shop tune. Both are great. And both blow EC out of the water.
Compare to EC, these two tunes run like day and night. I understand EC is known for being "conservative" but I have not heard any issues with Vtech or MSS at all.
For TCU tunes, MSS is THE best. They offer the 4-mode TCU tune. You will be able to adjust the way you car shifts with the S/W switch next to the shifter. There is Agility (A) Mode, Comfort (C) Mode, Sport (S) Mode and Manual (M) Mode. If you click S/W in whatevr Mode you are, the gear display shows what gear you are currently in and prompts you to shift up if you are in Manual mode. Btw, if in true manual mode, it will ONLY shift when you want it, too. So it's the closest to a true manual gear you can get.
Love it. Really woke up the Transmission. Can only recommend, especially for SRTs but I'm sure even N/A will see quite a big difference.
You can always buy the Latemodel21 paddle shifte kit and oh boooooy. It's fun! He can also supply the TCU tune together with the paddle shifter kit. And it's relatively easy DIY
Old Mar 9, 2026 | 07:17 PM
15 years AGO I HAD A TRANSMISSION TUNE along with 5 other members and two from MBworld we all 8 of us lost our tranny within a month or so and they would not admit or do anything for us the other people dropped it i did not, and after a few months of posting was band from getting any kind of tune ,engine or transmission or anything so i do not recommend them jim
Old Mar 16, 2026 | 04:19 PM
nickwe21's Avatar
That sounds terrible, Jim. Are you referring to Eurocharged, Vtech Georgia or MSS? Just so we are not spreading false info here or accusing someone who might have had nothing to do with it? What happened to the transmissions? I would have been very very upset. Plus I hate a business that doesn't stand behind their products. If you mess up, admit to it, make it right and do better the next time. Of course, most tuning companies will tell you "at your own risk". It could be total coincidence if someone gets a tune and a day later parts break but if it happens to multiple people and in the same way, that is facts!
Old Mar 16, 2026 | 09:33 PM
"Are you referring to Eurocharged, Vtech Georgia or MSS? ????" I will answer this way never used Vtech Georgia &
love MMS also had two tunes from two different in Miami liked those too . today I have had Morrison Tune Chicago,
good but that tune from him is over 10 years old, New technology MMS is the best he has a bar none TCU tune. JIM
Old Mar 18, 2026 | 11:09 AM
bc75's Avatar
I got my TCU tuned from MSS last year. I'm loving it really woke up my 04.
whoosh
21
Feb 24, 2014 08:30 PM
Russcross
Aug 21, 2012 09:37 AM
Cydetrak
Canada
252
May 3, 2011 07:34 PM
EUROCHARGED
Jan 23, 2010 12:39 AM
EUROCHARGED
Jan 23, 2010 12:38 AM
