Supercharger shim size and harsh engagement
Old Today | 12:32 AM
nickwe21's Avatar
Default Supercharger shim size and harsh engagement
So I recently replaced the bearing on my aftermarket 65mm pulley.
Could be coincidence but ever since, I hear a "metal" sound when the Supercharger engages. Could be a chirp but sounds more like a rattle.
At the same time, it just seems like it's a harsher engagement. So I checked the pulley gap. If memory serves me correctly it's supposed to be between 0.25mm-0.35mm.
It's closed at the moment but it's not rubbing on the magnetic plate.
1) What is the correct gap?
2) I never needed a shim before and I cannot find the shims that came with the OEM pulley. What is the thickness and size (diameter) of the OEM shims? I want to have some made just in case. My machine shop will make them for free
3) Is the harsh, jerky engagement a problem? Some people think as long as the backing plate is not rubbing against the magnet,life is good?
Should the measurement be taken when components are hot or cold?
Do you guys take sandpaper to the backing plate to smooth it out?
For some reason I feel like power is gone. But maybe I'm just imagining that.
Thanks for all your tips.
Nick
Old Today | 08:49 AM
zip439's Avatar
Default Re: Supercharger shim size and harsh engagement
@nickwe21 You should know this by now click the link and scroll down to the SRT6 engine section: Your questions will be answered CLICK
nickwe21
Jan 12, 2026 10:22 AM
rmcdaniel12
Aug 29, 2020 10:33 AM
TheStig
Apr 23, 2020 09:32 PM
vinnys
Jun 29, 2015 09:33 PM
Billy22Bob
Aug 5, 2014 12:19 PM
