How to detail your Crossfire!!
Thanks everybody for all the tips, I have been washing my car on the regular using the info here like a bible. I do have a couple questions though. I picked up a 60$ black and decker polisher and ran it over the car using the Meguiars 3 step system and the only thing I noticed was the wax works well. After I was done the whole process (took forever) I walked across the street to check it out and it looked like one giant swirl in the sun
. I’m not sure if it is just a crap polisher (even if it is it should still help a little) or if it was the pad I used. I assume it was most likely the pad, it was a wool pad but I don't think it was good enough to get to the swirls. Do any stores carry these foam/more aggressive pads? I can’t seem to find anything at places like AutoZone and I prefer to pick things up at a store if I can. Also should I just grab the porter cable and give up on the other? Thanks for the help!
Hmmm...I have no idea what polisher is $60 from black and decker, but I bet the pad you used was way too aggressive. Try Menzerna polishes and a less aggressive pad first (like Lake country blue foam ccs), then a more aggressive pad (like the Lake Country orange foam ccs) followed by a less aggressive pad if the less aggressive pad by itself does not do the job. Autogeek.net and properautocare.com are some of my favorite places to go for quality detailing products. Locally you might want to ask your local body shop where they get their supplies (it's probably local).
I used the second step cloth (dont have on the site ) with some scratch X and paint cleaner/conditioner
then used http://www.sears.com/shc/s/p_10153_1...keyword=buffer For the polish and http://www.sears.com/shc/s/p_10153_12605_00928494000P?keyword=buffer for the wax.
It did shine really nice but that almost made the swirls more apparent.
Couple pictures, hard to get it to not autofocus on the reflection but should be able to tell. (PS I Hate Polin, i swear i just washed it a few hours ago)
Sorry to say that buffer just isn't going to get the job done, especially with our very hard clear coat finish. I'd bet the wool pad you used put some of that marring into the paint, but you should be able to get that out with a proper DA polisher - the Porter Cable 7424 or the new Meguair's G110 - and the right pads and polishes.
I highly recommend you check out autodetailingsolutions.com, specifically Package #2 at http://www.autodetailingsolutions.co...20Specials.htm as this will hook you up with practically everything you need to get started. But regardless which pads and chemicals you use, technique is EVERYTHING when it comes to machine polishing. At least with a DA polisher if yoiur technique is bad the worst that will happen is you'll just push the product around and not get a lot of results. You will NOT damage the paint unless you drop the machine on the car.
You might also want to check out the forums at www.meguiarsonline.com for some detailed info on proper techniques for machine polishing.
I thought I may be able to contibute! Sorry; Golfdude just blew me away. I've used Clay Bars before and they are unreal, but I never knew the detailed method descibed.
This Forum is fantastic; thanks for sharing your knowledge.
For what it's worth---- " I love this car!" and I've had a whole lot of cars.
Next objective----what is the most bang for the buck onHp?
Thanks!
Thanks!
Thanks for the compliment maclovinX! Airscape, I don't know where you are located, but if you are between VA and NY I might be able to stop on by to show you some detailing tips and tricks.
I read a lot of good posts about revitalizing the paint. But my question is about "final wax" or a maintenance type product.
Has anyone had any good results with any finish type waxes, preferably a spray on type that can be used to keep a good slick shine on a car that is garaged kept? I know that Meguiar's has several different number applications available, but I have not done any experimenting yet.
I've had good results with Duragloss Aquawax (cheapest), Optimum Spray Wax (mid-priced), and Zaino Z8 (most expensive). The Optimum Spray wax beads like crazy and all of these products create a slick surface. Zaino Z8 offers a very glossy appearance while Optimum Spray Wax looks P21S-like...a very wet, deep look. Aquawax is inbetween in appearance. The old Meg's NXT and Eagle One's similar products are not as easy to remove, but they are easy to find. The new "hydrophobic" brands from Meguires look interesting.
After a thorough cleaning, then a session with a clay bar, I applied 2 coats of Meguiars NXT 2.0 24 hours apart. I think the ease of removal has to do alot with the cleanliness of the paint as much as anything else.
The NXT 2.0 is quite nice in that you can do the WHOLE CAR, wait an hour, and remove it with microfiber towels as easily as wiping down the kitchen counters. Mine is garage-kept and is 2 months old. Looks great with an occational good wash and dry, then application of Meguiars Quick Detailer (it all came in a kit).
I would use the detail spray after every wash. It really makes a difference.
Golfdude - Take it from a Zaino zealot, the Z-6 is all you need, the Z-8 may smell like peaches but quite frankly I couldn't tell a difference and I think its more expensive than the Z-6. I gave the remainder of the Z-8 to my son.
Pat
Pat
Patpur - I actually have both z6 and z8. I personally feel that z6 does clean and slicken the surface, while z8 adds even more slickness and more gloss, and it beads well for the short time that it lasts. I could certainly tell the areas sprayed with only z6, and areas sprayed with z8. The difference in appearances between the two products probably vary from color to color. Yeah, z8 certainly smells good too and it is much more expensive. I haven't tried their clear seal product yet. Their ZAIO is pretty good too, but it doesn't clean the paint as quickly and effectively as Optimum poliseal. But, I will probably be getting ZAIO to create a base for z6 and z2 pro.
Thinking about the context of your response Patpur, I am probably going to aggree with you that z6 is better for weekly "clean-up" after washing. Z8 does not seem to last anywhere near as long as any of the other spray waxes that I mentioned, but I still feel it really boosts-up the shine and slickness of a paint surface.
Here are few kits that look pretty good:
http://autogeek.net/optimum-kit.html
or
I would JUMP on this kit asap because it has truly everything good:
http://autogeek.net/meguiars-da-foam-pad-kit.html
But, I do feel the need for a FLEX machine, because it does a faster job:
http://autogeek.net/flex-orbital-polisher.html
If money is no object, this is the kit to get...simply the best in my opinion:
http://autogeek.net/menzerna-flex-xc...w-car-kit.html
or
Anyone ever use this stuff called "Final Detail"?? It is a spray wax but works like a quick detailer... It is by far the best I've found and it works great after each wash...order it on www.finaldetail.com It acts almost like an alcohol based product would...you spray it on and begin to wipe it off and it quickly evaporates.
