Fixing a dented door?
Old Jan 27, 2008 | 10:51 AM
kbroz's Avatar
Default Fixing a dented door?
My door has a dent from the previous owner that has some touch up paint. It's not that big of a deal as the car is a very low mileage daily driver I just purchased... but does anyone have any idea what it costs to fix a door dent? I'm not sure if they charge extra for the side curtain air bags and stuff.
Old Jan 27, 2008 | 12:58 PM
+fireamx's Avatar
Default Re: Fixing a dented door?
I think the price that Dent Wizard charges is directly related to how long it takes for them to massage the ding out. On a door, it's usually pretty easy to reach the back side of the entire door panel to get "behind" the dent.
I would guess the cost would be in the neighborhood of $150 or so.
It usually doesn't take very long at all.
I believe there is a Dent Wizard right off Rt.271 by the Randal Park Mall.
Old Jan 27, 2008 | 01:08 PM
Yep, typically $80 - $100 per panel.
Old Jan 27, 2008 | 01:51 PM
Moparrbust's Avatar
If it has touch up paint on the dent then I can guarantee that it will need to be painted. Depending on the location of the dent and the color of the car you will also have to blend(paint) the adjacent panels(fender, 1/4 panel) as well. On top of that everything on each panel being painted will have to be R/I'd(Remove/Install) to be painted properly...and THEN the cost of repairing the actual dent. The cost could vary anywhere from $450-1400 to fix it the "correct" way.
Old Jan 27, 2008 | 02:11 PM
kbroz's Avatar
I'm not too worried about it being perfect. If they can pop the dent out I will worry about paint later. Thanks for the input. I'll check out dent wizard.
Old Jan 27, 2008 | 02:27 PM
+fireamx's Avatar
Let us know how much they charge ya. The last time I had it done (about 10 years ago) it was around $150. But now that I think about it, they may have fixed more than one dent.
Old Jan 28, 2008 | 01:06 PM
Nightrider's Avatar
A small dent from a scratch just under the door handle was estimated at $625. Had to look hard to see the dent and 2 3' scratches not thru the paint. The 650 was for paint only another 125 to smoothe dent.
Old Jan 28, 2008 | 05:46 PM
R/TommyB's Avatar
Out of curiousity, a Crossfire I am looking to purchase has a small blob of touch-up paint on the passenger side door. No dent, just what must have been a nasty door ding.
Texture-wise, they did a good job on making it flat, but it is a terrible color match. Any tips on how to get the old touch-up paint off so I could try a better match?
Also, do they make interior touch-up paint?
Old Jan 28, 2008 | 06:11 PM
Nightrider's Avatar
I found this site AutomotiveTouchUp.com that claims factory matched paint (about $20) a friend of mine uses. There are also some excellent touch up kits available for about $25. I used to do body work years ago...today it is a total rip-off.
6 inch of bumper rubber roughed the surface (caused 2 about 3 inch not thru paint scratches that caught finger nail)of my door below the handle $650. When I aeked...we have to disassemble the door and remove both quarter panels to blend the paint,. BULL DOODLE!!!! $30 of touch up and good buffing (hour labor is appropiate. Shouldn't cost over $100.
Old Jan 29, 2008 | 02:08 PM
kbroz's Avatar
Well, I tried a home remedy using a hot/cold method. It actually seemed to work some. I imagine it would've worked better if A) it wasn't as cold outside and B) there was no touchup paint on the door. The paintless dent removers say they paint cannot be broken. I will check it out on Saturday and keep everyone updated.
xfClifford
Mar 3, 2021 04:52 PM
deerhunter
Jan 16, 2021 10:56 AM
pcrs29
Aug 29, 2015 12:21 PM
55chevy
Jul 20, 2015 03:08 PM
tom2112
Jul 12, 2015 04:41 PM
