What's the best wax for my black crossfire?
The main reason to use the PC or similar unit is that they are orbital, as a result far less likely to burn the paint for someone less experienced.
I don't think there is an orbital air tool. Feel free to correct me if I am wrong.
Originally Posted by Michael M
I'm a new owner of a black 05 Roadster. It is a higher mileage car, but still has beautiful paint. I can see some swirl, but have to get it in the sun and look for it. Will start on the finish as the weather allows.
Regarding the DA polisher - how is the Porter Cable on other paints? Any experience among this group? What about air driven polishers? I would rather use an air tool, but suspect that even a little oil from the exhaust would show up in the paint.
I'd welcome any information or opinions.
Thanks,
Michael
Thanks,
Michael
Originally Posted by Aintgonnahappn
But to add something a little constructive, I have always heard that over waxing a car is not a good thing either. It can add a haze effect to the finish, max about two times a year. Is this not correct?
Keep your car clean, wax it 4 times a year, and use a quick detail spray between washings to remove light dust and fingerprints. Use a spray wax between proper wax jobs too, especially just after washing, to help keep the shine up to a max level.
l
l
Michael, pick up one of the above mentioned electric DA buffers and you'll never look back. And for the very hard paint found on the Crossfire (brace yourself, shameless plug coming.......) might I suggest Meguiar's new DA Microfiber Correction System? We (yes, we - I work for Meguiar's in case you didn't know) just released this system last month and it's making huge waves in the detailing world. It will let you get near rotary results but with the safety of DA use. Plenty of info on our forum at meguiarsonline.com, or I can expand on it more for those who'd rather learn about it here instead. I'm just trying to be sensitive about coming across like I'm just shilling here.
While it is possible with some old school carnauba ......... I'm just trying to be sensitive about coming across like I'm just shilling here.
Mike and Karl,
I appreciate the feedback. I have never owned another car that was worth bothering with these details. I am glad to get information on the products you are sold on. You can't help working for a company you are proud to be associated with.
Another question I have regards other vehicles. I do have several mid-60's MOPARs, and as I manage to get paint on, can I use the same information on older technology paint? None of those cars got clear-coats, and none of mine will.
Again, thanks for any information offered!
Michael
Michael
First, the obvious part is that you can see paint transfer onto an applicator pad when using something even as mild as a cleaner wax - if your car is black, the applicator will turn black, a red car will turn the applicator red, etc. Perfectly normal, and the only reason you don't see this on a modern car is because the trace amount of paint you're removing is clear.
Second, single stage paints tend to be more worker, or softer, or more delicate, or however you want to phrase it, than a modern catalyzed clear coat is. This means you can often use less aggressive products to correct defects. Just keep in mind that if you're dealing with original, old clear coat and you don't know the full history of that car, the paint could be very thin in spots. Even if it looks really good, that thinness can bite you when you least expect it. Be careful around raised body lines, panel edges, etc.
Third, single stage paints love products with a lot of polishing oils in them, especially the darker colors. A light cleaner/polish like M80 Speed Glaze from our Pro Line is incredible on dark single stage, whether you're working by hand or with a D/A. The added depth and gloss provided by this type of product can really make those darker colors look deep and wet. Something like M07 Show Car Glaze if the finish is swirl free works great too. You can finish off with any wax or sealant you like after that.
In the end, it all depends on what you want out of the finish (daily driver, show car, weekend toy, full concours prep, etc), how much time you're willing to devote to the process, and what your skill level is.
might I suggest Meguiar's new DA Microfiber Correction System? or I can expand on it more for those who'd rather learn about it here instead. I'm just trying to be sensitive about coming across like I'm just shilling here.
Mike,
Thanks again for the information regarding the non-Crossfires. The Darts and Barracudas are mostly solid colors, but a couple are metallic. I'll probably use a catalyzed acrylic enamel, similar to what was put on those cars in the 60's. I have shot a couple, but have a lot to learn. Only the Crossfire is black, and one black car will be enough work for me!
Michael
Michael
Mike, if you would not mind imparting some knowledge (and rough pricing) on the new system, I know I would appreciate it. TIA
Key to using the system is to use a very small amount of product - like 3 or 4 drops of product for each section one the cutting pad is primed. But you also have to clean the pads with a pad brush after every section. It's critical, but not at all the time consumer you might think. If you have access to compressed air, all the better. Wipe off of both liquids is insanely easy (the finishing wax will probably the single easiest wipe off product you've ever used) and there is no dust, no sling. Pricing is very competitive too, especially when you consider the life expectancy of the pads and small amount of product you use.
I've got a full write up on using the system at Using Meguiar's D/A Microfiber Correction System - Car Care Forums: Meguiar's Online and there are plenty of independent reviews on the system both on our forum and autogeek.net and truthindetailing.com
Oh the joys of keeping a black car. I've only had one black car in my life time and I will have had only one black car in my life time. They do look great when they are clean and spotless, but I just don't have the time to keep one up the way it should be. I'll take my little white car all day long. Cheers
Bout time to buff the winter off the car, checking for new product and seen this thread. Any places have a package deal for the new meguiars system? I have some big lake country pads but looks like these new ones were designed for the system and I could use some smaller ones for certain parts of the car anyway. Would really like to give this a try as the ultimate compound couldn't quite get a couple spots that I have (crazy demon bird purple **** marks) if not just any place to find all the pieces, apparently I'm blind because I can't seem to find them. Thanks!
Airscape, if you're talking about the Meguiar's DA Microfiber Correction System you should check out either autogeek.net, autodetailingsolutions.com or detailing.com - all three carry the whole system and all three have great pricing.
For use with a typical DA buffer you'll want the correct backing plate to start (it's pretty important, actually) so pick up Meguiar's part number W67DA. You'll also want a two pack of DMC5 cutting discs and DMF5 finishing discs, then a 16 oz bottle each of D300 DA Microfiber Compound and D301 DA Microfiber Finishing Wax. A good pad brush is critical as cleaning the pads after every single pass is critical And yes, just a 16 oz bottle of each is more than sufficient to correct your own car a few times - a very small amount of product goes a very, very long way.
Not to hijack the thread further but how long should it take to do the whole process? I'm getting a bit quicker but it is still basically a full day job with wash, clay, polish and wax. Maybe I am just overdoing it but I know I could be doing something better / more efficiently.
So, how long will it take you? Somewhere between 2 and 10 hours most likely. Depends on all of those aforementioned variables.
Read through the write up on our forum before you use the system - it will save you a bunch on the learning curve. Using Meguiar's D/A Microfiber Correction System - Car Care Forums: Meguiar's Online
From that same thread, here are a few before and after shots of a black SL 55 AMG I buffed out for a customer using this system:
This is what the paint looked like everywhere on the car - just a mess:
And this was about 6 hours later - two steps, done.
Thanks again for taking the time to share your knowlege. I don't feel so inept now
. I had seen the alabaster thread when it was started and after a 12 hour session on my ride I figured I was doing something way wrong as far as speed goes. I have only done the whole process about 4 times now but I have it down fairly well. My swirls are nowhere near that SL55 anymore, maybe right after I got it. Now I would say just the big outer rings are starting to form. She lives outside and gets washed way more frequently than I would like but I am more than pleased with how long the ultimate compound and #26 wax keep it looking great. My biggest issues now are the wheel wells and other low sections that get all the rocks and dirt flung on them. I think there are just to many bumps and scratches at this point to get those sections 100% after 55k with the tools I have. There are a couple deep scratches here and there that I just have to live with as well. When it's all shined up though I am probably the only one that can really pick them all out easily so can't complain too much. Thanks again!
imported_mightyjlr
Detail Shop
41
Jan 1, 2016 10:16 PM
bmaynard06
Jun 22, 2015 09:04 PM
