Excessive tappet noise on cold start-up
My 2005 Crossfire makes quite a lot of tappet noise on start-up from cold. The noise gradually goes away after about 5 mins (once warmed up) but is this noise normal on the 3.2 V6 engine? Its very noticeable even though my car only has only covered 34,000 miles and is regularly serviced (including oil change).
Any advice would be welcome. |
Re: Excessive tappet noise on cold start-up
Any advice would be welcome. Had similar problem, Oil change and driving it a little more helped. Cheers. |
It's all good in da hood... just pretend your driving a porsche. :D I still haven't figured it out myself nor have many MBZ mechanics. I've heard people say its related to the timing gear sprocket, it needs to get oiled before the noise goes away, then another theory where the silencing rubber coating on the sprocket has worn away. also if the oil sprayers to the sprocket gets plugged it will make the noise. Then there is the issue of tolerance in the cylinder bore, I know many late model chevy motors with piston slap issues until fully warmed up, none of which are harmful to the engines life. So I just live with it. it only last a couple seconds and then its gone. But I doubt it's related to the valve train.
Also there is a check valve on the driver's side compartment that make a loud ticking sound, completely normal. |
Any advice would be welcome. https://www.crossfireforum.org/forum...earchid=305651 https://www.crossfireforum.org/forum...earchid=305657 |
this is his first post go easy.
Perhaps a mug of hot chocolate would be in order, not aspresso? Go easy! ;)
Originally Posted by HDDP
Here's some advice... USE THE SEARCH BUTTON ! OR if you ask another question without using the SEARCH BUTTON we will all ignore your future posts !!! OR we will make serious fun of you, and you'll feel like a MORON... The internet is not NEW, you might be, but the system is not... When you join any forum and have a question, you can use the SEARCH BUTTON !!! Not to make fun of you, but you will probably NEVER have a question about this car that has not been answered before...
I read your post and thought I should reply.
About 10 years ago I worked for a Chrysler dealership. One of the problems some motors with aluminum block encountered was a thing called piston slap. This would occur at cold start up then quiet down once warm. My understanding is that until the rings warmed and expanded, the piston was slapping within the cylinder. This piston slap sounded more like a knock knock than the click click of a tappet. A bent rod can increase the contact distance and cause tappet noise. A motor which has been run low on oil and ran hot can develop noisy tappets among a list of other things. I'm no mechanic... |
Since it has only 34k is the 3/36 warranty still good? If so get it into the dealer soon, so you can verify the existance of the problem before the warranty expires. There are may possibilities, from chain tensioners, to valve train to piston slap, none of which should be occuring at 34k. If you bought it used, did you have the factory warranty transferred?
all the m112 engines make this noise, check around the mbz forums, it's normal though it is a little too fast to sound like piston slap.
HDDP IS A JERK OFF. I TREAT MY DOG BETTER THAN YOU TREAT PEOPLE GET A LIFE A-HOLE.
https://www.crossfireforum.org/forum...earchid=305651 https://www.crossfireforum.org/forum...earchid=305657 Searchid's are not kept for very long by the BB system, so the links die after a short while. One of the hardest things for users to know to search is what keywords will quickly land them on the prior posts. What do you you search for when you don't know exactly what it is called that you are searching for? |
Thanks for the advice guys. I'll check out some of the things you suggested. The engine is peachy when warmed up and I've no other complaints but the cold tapping seems out of place on an engine which has been well maintained, fairly low mileage and hasn't been abused or raced.
As for HDDP's 'advice', well, we all have a bad day I guess. Put it down to male PMS! (only kidding). This was the first time I'd posted a thread on your site, and I don't use forums normally (I find the telephone usually works better and is quicker!), but it's cool. I'll definietly be back however so thanks again for helping a fellow Xfire enthusiast from across the pond. :cool: Cheers, Ecosse_Cross |
nvmd, already brought up.
Mine gets loud once and a while when it's cold. I just give it a good thrashing and it goes away for a while.
you have to understand where HDDP is coming from, he works on Hollywood sets with many arrogant rich bast@rds everyday, and lazy Union slobs, sooner or later it will turn the sweetest person into an A**hole. ;)
clicking ticking clatter
usually the lifters, when the oil reaches them.. pumped up the sound goes away , but 5 min time frame wow ! |
