IC Pump Fail? How do I know for sure?
Old Jul 23, 2008 | 10:35 AM
tom2112's Avatar
She can ride with me ;)
Default Re: IC Pump Fail? How do I know for sure?
I'll swing by Pep Boys on the way home and pick up some MAF cleaner.
Old Jul 23, 2008 | 02:03 PM
dejohnny's Avatar
Originally Posted by Voyager
yeah that doesnt sound like the ic pump. sorry man it looks like your going to have to search around that engine. if it was the ic pump you would be running ALOT slower
Voyager I love your signature. That was absolutely brilliant!
Old Jul 24, 2008 | 04:12 PM
tom2112's Avatar
OK, I printed chapter 14 of the service manual, and it only has one section about removing the MAF sensor, and it's on the normally aspirated engine.
Sadly, I can't find the MAF on my SRT. Evidently, I need the "for dummies" version. Can anyone point me to a photo with a nice arrow pointing out the MAF? I don't want to just start taking intake parts off until I stumble across the darn thing.
Old Jul 24, 2008 | 06:40 PM
BrianBrave's Avatar
<--- Huge Horsepower
There is no MAF sensor on the SRT.
The MAP sensor is found in Section 7 - Cooling - Charge Air Cooler
The manual fails to mention the IAT Sensor in Section 9 - Engine/Supercharger/SuperCharger Outlet Tube. But it's there.
I have a pic in my gallery.
Old Jul 25, 2008 | 08:18 AM
tom2112's Avatar
Damn! No wonder I couldn't find it!!!
So, there's no reason to clean it either. Should I clean the MAP sensor instead?
Yes, thanks for the pics. The ones in the thread you posted above were very informative.
Old Jul 25, 2008 | 05:17 PM
Kurts's Avatar
So the manual is incorrect Brian?
I went out last night & was trying to scope out the location to see if i could help Tom out but couldn't find the little devil: getting dark so I just gave up with the plan to remove my Needswings intake sometime this weekend & do a search for it.
Old Jul 25, 2008 | 05:25 PM
BrianBrave's Avatar
You have one on the N/A
Old Aug 2, 2008 | 07:28 AM
tom2112's Avatar
Well, I went to the track again last night. Still no love. 13.3, 13.3, and a 13.2.
However, I did take my laptop and some OBDII software and logged data from my runs. I hope it can tell me something.
Old Aug 2, 2008 | 07:58 AM
laloggia's Avatar
Tom,
I'm sure you already tried this, but reset the computer too...disconnect the battery for 1/2 hour. See if that helps.
Old Sep 11, 2008 | 09:16 PM
tom2112's Avatar
Well, a little update is overdue. Wednesday was an awesome day in north-east Ohio for racing. The temps dropped into the 50's and reasonable humidity between 30 and 50%. So I went to the track - Thompson Drag Raceway.
My first run there the temps were in the low 70's and I ran a 12.76 @ 110.67. Not too shabby! I was pleased but I still think I should be doing better.
Unfortunately, there were a lot of cars there that night, and there were lots of delays. I only got three runs. I screwed up the last two - spinning tire at launch - and run 13.0 and 13.3.
Anyway, part of the mystery may be coolant. I tried to check my car's coolant level, but there are no lines on the coolant overflow tank that indicate what is normal level. So I filled it up with distilled water. I figured any excess would just come out and end up on the ground. But if it was low, it would help in cooling.
I don't know if it made any difference, or if my 12.7 was simply attributably to low temps alone.
Old Sep 12, 2008 | 04:35 PM
Kurts's Avatar
Thanks, Tom!
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
tritongreen
Sep 18, 2015 07:32 AM
RacerXofFL
Sep 15, 2015 05:00 PM
