Question about superchargers
Hello everyone i own a 05 Xfire normal engine and im really bored with the power so i check the internet and got stuck with the srt-6 supercharger and te Kleemann supercharger but the question is did anyone of you tried to install a one on there xfire and what do u have to change with it.
Thanks..
Thanks..
Please use the SEARCH function. This has been discussed exhaustively
In short. Mating a S/C to a N/A motor is not overly difficuly until you begin to rework all the elctronics.
Ask ChuckNorris.
Ask ChuckNorris.
Ask ChuckNorris.
Ask ChuckNorris.
If I had to do it over again I would sell the engine and tranny and do a motor swap. Its not impossible to supercharge, just a lot of tinkering to get everything hidden from the ecu. Don't use a conventional water to air or air to air intercooler either. Meth/water injection is a must with 10:1 cr. Until someone figures out how to run a 2bar map sensor with the factory ecu its just not worth it. If I end up keeping my Xfire it is going to get a non MB V8 that has plenty of aftermarket parts/tuning abilities.
That depends on how much money you have.
Originally Posted by samo59
If the Crossfire can be twin-turbocharged, and I think it can if you have a lot of money, how much horsepower do you think it can produce?
-Sam
-Sam
Originally Posted by Kagen
I was wondering the same thing about the supercharger. I wish the srt6 came with a 6 speed, I would rather have a stick then have more power though
lol
440bhp @ 1 bar boost (14.7 psi)
660bhp @ 2 bar boost (29.4 psi)
880bhp @ 3 bar boost (44.1 psi)
1100bhp @ 4 bar boost (58.8 psi)
Now, if you were to modify the N/A hp to 200whp using top-end work, then you could theoretically make:
500bhp @ 1 bar boost
750bhp @ 2 bar boost
1000bhp @ 3 bar boost
1250bhp @ 4 bar boost
Originally Posted by sonoronos
Approximately:
Never tried putting it on. I don't think it would have fit, the clearance was pretty tight between the pulley and hood.
Are you able to have the cover on with that supercharger on the plenum
Bolt on yes, selling no. I do have several 1/2 inch waterjetted aluminum flanges left over that I used to build mine. I started building manifolds for my turbo project too out of them. I'll probably stack a few together to create longer runners. They are gasket matched. I still have a lot of work to do on them. One day I may find the time and motivation to complete them. Tons of room once the original manifold is removed. My original idea was to mount the turbo like eurocharged did but I think the remote mount is a better idea to keep the temps down. I don't want my turbo to spool until 3k anway. The NA really only suffers from a lack of top end power IMO.
So is that pretty much a bolt on thing? Are you selling it?
I finished the Supercharger and drove it over 7000 miles. Right now my car is back to stock. I'm lacking an oiling system for the turbo and have a lot of other things going on in my life right now that are preventing me from completing it anytime soon. If anyone has a house for rent in Huntsville send me a PM!
So Chuck Norris, r you gonna attach a turbo to your crossfire or no? Wouldn't your supercharger project have been easier?
-Sam
-Sam
