Question about superchargers
Old Jul 25, 2009 | 06:50 PM
samo59's Avatar
Default Re: Question about superchargers
Oh, i see. Well, good luck with all the modifications. If you installed a supercharger, you should be able to install a turbo. Did you work as a mechanic or did you teach yourself how to do all this?
-Sam
Old Jul 26, 2009 | 01:29 AM
ChuckNorris's Avatar
Mechanic for 19 years now, thanks for asking, I hadn't realized it had been that long until you asked. The Crossfire is certainly a different breed of programming though. It took me months to work out all the details and I know why the others before me had problems. Domestics take about a tenth of the effort to manipulate.
-Sam
Old Jul 27, 2009 | 04:17 PM
samo59's Avatar
Oh wow. I worked with a mechanic for one year I dont even come close to your mechanical car abilities haha. Thats great man, keep up the work and keep us posted on any of your new inventions!
-Sam
Old Jul 27, 2009 | 06:06 PM
ZAHANMA's Avatar
If the Crossfire can be twin-turbocharged, and I think it can if you have a lot of money, how much horsepower do you think it can produce?
-Sam
Well seeing as the single turbo is making about 428rewhp on a DynoDynamics (506rwhp on a DynoJet) at a little over 1 bar... a TT setup could make a good deal of HP...on an SRT6 motor, can't say for an N/A motor.
The problem you run into is a space constraint, seeing as I am not a huge of remote mounts (though I will admit there are quite a few amazingly fast cars with remote mounted TT setups). There are several other factors you have to take into account if going for a TT setup, the other biggest one I can think of being reaching torque limits controlled by the TCU, which there is only one person I know of that has hit that on a M112 engine.
Old Jul 27, 2009 | 10:08 PM
samo59's Avatar
So, when you say a TT setup works very well with an SRT6 engine, do u mean after the supercharger is removed or with the supercharger still on? I am assuming that you mean removing the supercharger and then TTing the engine. So then the N/A engine of a crossfire is different than an SRT6 engine in ways other than the fact that it has a supercharger?
-Sam
Old Jul 28, 2009 | 09:59 AM
Different rods and pistons for lower compression ratio as well as other parts. The NA is still a stout motor sharing a guestimated 75+% of parts. I believe the SRT also has a beefier tranny.
-Sam
Old Jul 28, 2009 | 10:09 AM
ZAHANMA's Avatar
please understand me, i DO NOT KNOW if a TT setup would work. There is only one SINGLE turbo setup that I know of making real power...
So to jump and say a TT setup would work well is a bit of a stretch.
...in theory it would work since eurocharged has been able to basically redefine the ECU on the SRT6.
Old Jul 28, 2009 | 02:58 PM
samo59's Avatar
Ohh. Thanks for answering my questions guys!
-Sam
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
