Project Crossfire - a Rotrex Supercharged Limited!
Old Aug 1, 2010 | 01:16 PM
  #241 (permalink)
JHM2K's Avatar
Default Re: Rotrex Guy
Originally Posted by Web 3.0
Not yet, but soon. I started it 3 times, ran inside to make a youtube account, post the videos, and grab a drink. I'm going to let her run a while, check fluids, check idle, look for anything that might be rubbing, burning, shaking, etc. Then I'll probably take a couple of quick loops around the block and back to the garage for another round of inspections!
No doubt you'll do everything the right way. Test, measure, test, measure, and test again. That is what has made this thread a truly interesting read from the start. You're truly going about this the right way.
If you decide to market this, and once you set a price point (so I know how much to start saving for) consider me a future customer!!!
Old Aug 1, 2010 | 02:26 PM
  #242 (permalink)
32krazy!'s Avatar
sorry dude your engaged to be married!! your modding days are over!! i see you modding a lawnmower in your future!
Old Aug 1, 2010 | 02:44 PM
  #243 (permalink)
Web 3.0's Avatar
Son of a *****!
Old Aug 1, 2010 | 02:45 PM
  #244 (permalink)
Originally Posted by 32krazy!
sorry dude ........ i see you modding a lawnmower in your future!
Lawn mowers are easy to slam as well.
Old Aug 1, 2010 | 03:05 PM
  #245 (permalink)
Web 3.0's Avatar
Man o man o man!!!!
I am dead serious, that is the most perfect first test drive I have ever taken, period, in any car, ever!!!!!
  • I let her idle up to operating temperature and had to add some fuel to my old map
  • I then had a fair amount of hesitation on very slight throttle so I upped the TPS enrichment
  • Played with fuel until the fuel trims leveled out close to zero at idle
  • Shut her off
  • Double checked everything by look, feel, touch
  • Started her up and went for a 5 - 10 minute drive when all I set out to do was go to the first stop sign and back
I'm not kidding, aside from a very slight hesitation with a feather foot on the throttle, it was brilliant! I ended up getting her up to 15% throttle (low rpm), 13.4% engine load and about 45 mph.
I was also very impressed with the BOV noise as it was non existent at idle or cruise. You hear it a little rolling to a stop or on throttle release but nothing like the jet sound of the old C30 on a 1.8l. Some might even like it this way as it wasn't annoying at all. However, I will still end up quieting it down.
Now get this!!!!!! I'm sure this will change over a much longer run but the IAT's were very impressive. With the stock intake I was seeing an early 25 degrees delta between the TB and ambient temps. This quickly went to 35 on the highway and ultimately 50 degrees on a hot day.
In this 10 minute drive, it was 95 degrees outside and the IATs never went above 108 at a stop sign!!!!!!!!!! Then when I hit the gas, it would go down to 104 then level off at about 106 while at a 35 mph cruise!
Also, coolant temps never went above 198 and seemed to hover closer to 196 or so.
That is absolutely freaking awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Edit: corrected spelling and TPS%
Old Aug 1, 2010 | 03:22 PM
  #246 (permalink)
JHM2K's Avatar
Clearly you underestimate me. She loves speed... that was one of my first criteria in the screening process
Old Aug 1, 2010 | 03:24 PM
  #247 (permalink)
JHM2K's Avatar
Man o man o man!!!!
  • Shut her off
I'm not kidding, aside from a very slight hesitation with a feather foot on the throttle, it was brilliant! I ended up getting her up to 72.8% throttle (low rpm), 13.4% engine load and about 45 mph.
This is stellar news. Keep up the fantastic work!
Old Aug 1, 2010 | 03:40 PM
  #248 (permalink)
Web 3.0's Avatar
I just double checked the logs and the TPS was never above 15%. Weird one that is, I would have guessed 15-20% by feel and is actually what I first typed before posting, but the AEM log said 70+ so I went with that at the last minute. Just now I was looking at my SPD logs and it showed 15%.
hmm...
Old Aug 1, 2010 | 04:08 PM
  #249 (permalink)
32krazy!'s Avatar
yes she does.. and a house and kids and a yard and diamonds..........
Old Aug 1, 2010 | 08:02 PM
  #250 (permalink)
GettinIt's Avatar
I know its not over yet..... But DAMN IM EXCITED!
SIGN ME UP!!!!!!!
Going to be ooo so nice to have a LTD with some *****!
Old Aug 2, 2010 | 12:48 AM
  #251 (permalink)
BrianBrave's Avatar
<--- Huge Horsepower
Nice work - - I'm sure at this point you can iron out all the little things....
Old Aug 2, 2010 | 01:17 PM
  #252 (permalink)
msheredy's Avatar
Hmmm now I'm starting to think to myself, do I want to do a turbo or install a Rotrex instead??? I wonder if the factory clutch could be made adaptable to the Rotrex unit?
Web in your experience how does the Rotrex compare to a turbo in a street car?
Old Aug 2, 2010 | 02:47 PM
  #253 (permalink)
Web 3.0's Avatar
Wow, I could literally write a book on this one but I'll to keep it brief and address the highlights as I see them.
For the Street:
· A Rotrex typically runs better IAT's
· A Rotrex is better for under the hood temps
o You can typically push it harder, faster, longer than a turbo at a comparable power level
· It typically creates a nice linear power band that is excellent for drivability
o It behaves itself enough for grandma to drive unless she puts it to the floor
o Its linear power band is fluid and increases until redline
o No severe excess of torque in the mid range then a gradual decline in output as with a large single turbo
o A Rotrex is going to enhance the natural characteristics of the motor
§ In fact, the Rotrex will make it feel quite simply, like you bolted a much larger motor in place
· The Rotrex has No lag whatsoever, throttle response is instant and almost always improved
o The Rotrex is always flowing more air then the motor needs so it ALWAYS has power on tap
o A car with a Rotrex always feels like it is ready to pounce
· The fun factor is through the roof for all of the above
What do I mean by this last comment?
The torque delivery of the Rotrex is linear and increases until redline. This equates to the feeling of sitting in a rocket that gets faster and faster and faster until you let off the gas. A turbo has a different feel. A turbo setup when matched HP for HP to a Rotrex making large numbers on a motor will typically hit incredibly hard at its boost threshold then taper off to redline.
That said, the Rotrex is not going to provide an ungodly kick in the pants. Instead, it is nice and smooth and predictable.
If you like controlled fury, the Rotrex is for you. If you like a wild *** kick in the pants and hanging on to life by a thread, maybe the turbo is better.
IMHO ->
Street, Twisties, The Dragon - I say Rotrex
Dragstrip - I say turbo and some monster tires to keep that torque to the ground!
There is a lot more to this discussion as you could also go off into electronic boost control, WI, etc. The answer is Yes, you could build a turbo to match the characteristics of a Rotrex AND have the ability to turn up the boost at will. However, at what relative cost and level of complexity?
It really all depends on what you want out of it and your application. Many people think it is about nothing but low end torque. I typically am on that boat, but there is such a thing as too much. Just ask the guys who can never seem to find a tire wide enough to keep their rubber from melting off the rim To me, the Rotrex is the perfect compromise and fits the largest number of "wants" on my well educated wish list.
Old Aug 2, 2010 | 03:13 PM
  #254 (permalink)
JHM2K's Avatar
For the Street:
IMHO ->
All of the above are reasons I'm staying tuned. Getting giddy about this thing!!
Old Aug 2, 2010 | 04:11 PM
  #255 (permalink)
msheredy's Avatar
For the Street:
IMHO ->
Appreciate all your feedback. I did forget to mention (unless you noticed my sig) that I have an SRT. I wonder what differences (if any) there would be in swapping the lysholm for the Rotrex? I'd assume that with some slight modifications to the intercooler lines it'd be an easy bolt in using your mounting system? Then if an adapter could be made to install the factory supercharger clutch onto the Rotrex you've theoretically opened up the SRT engine to a new form of supercharger(s).
Old Aug 2, 2010 | 08:11 PM
  #256 (permalink)
Web 3.0's Avatar
Default Couldn't Help Myself!
I couldn't help myself. I had an idea to dress her up a bit and instead of doing any tuning tonight, I came home, cut up the stock engine cover, and painted it to blend in the cut edges.
Old Aug 2, 2010 | 08:41 PM
  #257 (permalink)
MikeR's Avatar
Sorry Web, I like it better without the one sided cover..... but it isnt my car... so who cares what I like....
Old Aug 2, 2010 | 10:28 PM
  #258 (permalink)
it's not my car either, but I would trim the other side to match...lol....great work man, glad this is coming together for ya.....
Old Aug 2, 2010 | 11:37 PM
  #259 (permalink)
BrianBrave's Avatar
Default Re: Project Crossfire - a Rotrex Supercharged Limited!
You could sand & polish your intake manifold to match your FroznBoost Intercooler - now that would be sic...
Old Aug 3, 2010 | 08:13 AM
  #260 (permalink)
ZAHANMA's Avatar
I like the new cover too... have you thought about modifying the other side of the air cover so it looks symmetrical since you won't be need that side airbox either?
