Walmart has Fram oil filters
Old Mar 23, 2010 | 05:01 AM
Infinite's Avatar
Default Re: Walmart has Fram oil filters
Originally Posted by 70GT6
Regardless, the quality of Fram filters is no where near what it used to be.
While they will not rdestroy an engine, there have been problems (canister type especially). Splitting seams, cheap cardboard "valves" that quickly fail, rubber seals the fall off, and colapsing filter material. Simply just not worth the risk on a car you care about.
So far i've had two motors spin bearings due to the fram falling apart
Old Mar 23, 2010 | 08:10 AM
Ed Mahoney's Avatar
anyone know the numbers for Bosch & K&N oil flters ?? Thanks !!
Old Mar 23, 2010 | 08:24 PM
70GT6's Avatar
K & N = HP-7004
Mobil1 = M1C-253
Bosch = 72204
Purolator = L25277
Napa = SFI27078
Old Mar 23, 2010 | 09:18 PM
texas t's Avatar
Talking Re: Walmart has Fram oil filters
Mobil one 0-40 5.79 qt in store fleece oil filter Mann/ napa gold fil7078 16.99 do not know if the 40% off applies to this filter and u get a free cap http://ecatalograck.genpt.com/flyer/WebProject.asp?BookCode=mar10flx#
Old Apr 9, 2010 | 03:41 PM
beasticles's Avatar
Have only used Fram oil filters on my Crossfire, just MAKE SURE TO CHANGE THEM OUT EVERY 3000 miles or 6 months (depending on driving habits).
They work fine, they just need to be replaced more quickly than fleece.
Old Apr 9, 2010 | 03:48 PM
bmorgan's Avatar
Considering you can get the fleece filters for around $12, what would the advantage be to buying a paper one and changing it more than twice as often as you would a fleece filter. I am not seeing any advantages to this, and several potential pitfalls.
Old Jun 17, 2011 | 08:16 PM
OldSalt's Avatar
Volvo Parts, BMW Parts, European Car Parts | FCPGroton.com
I use this site for my S80T6 Volvo. I am inthe process of getting a 2008 Limited Coupe.
Is this the correct oil filter for the Crossfire?
OLD SALT
Old Jun 17, 2011 | 08:52 PM
OLD SALT
HU718/5X
That's the boy allright, good price.
Old Jun 27, 2011 | 07:48 PM
PubKrawl's Avatar
I purchased one of those Fram oil filters at WalMart. Big Mistake!
Let me start by saying I like WalMart. The only reason I bought the Fram filter there is because that is where I buy my Mobile 1 oil and pretty much everything else. I was working under the "if WalMart don't sell it, I don't need it" theory. I am not slamming WalMart here...just Fram oil filters.
I have known for years that Fram canister-type oil filters are an inferior product. They use cardboard components for their end caps, their check valves are prone to failure, their canisters are flimsy and they skimp on filter media. But, hey, the cartridge looked decent enough and it sure was cheap (I do like bargains).
I should also say that I always change my own oil. Bought the car with 24k miles and now has 90k. I've done seven oil changes now. I did not damage the o rings or drop anything into the filter assembly or commit any other typical 'user error.'
Upon unpacking and inspecting the parts I thought the o rings were odd (squareish). The squareish shape is difficult to explain, but I will try: If you were to cut the rings and pull them into a strand, they would be square at the end -- not round. It was as though they were cut from a rubber tube, rather than being made from rounded rubber strands. Deves piston rings are squared like this, and they are a great product, so the squareish appearance of the rings didn't prevent me from installing them.
So, I installed the Fram filter and the new "O" rings that came with it. The good news is that no oil leaked for about a week. Unfortunately, that was about it.
The best description of the catastrophic oil leak that soon followed is that my car 'puked' oil from the filter assembly. So much oil came spewing out that my serpentine belt slipped off. Oil was everywhere! Quarts of beautiful, new, expensive synthetic oil were all over my [previously immaculately clean] engine bay.
I replaced the belt and cleaned the oil from the engine using Simple Green (one of my favorite products). My alternator failed shortly thereafter. I can’t prove it was due to it being oil drenched, but I am suspicious.
In summary: Fram oil filters suck. Don’t use them on any vehicle you like.
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
Sep 28, 2015 07:40 PM
