Took off my Manifold Covers tonight and its not good...
Old Feb 22, 2013 | 04:24 PM
Default Re: Took off my Manifold Covers tonight and its not good...
Originally Posted by oledoc2u
install a low fluid sensor, or regularly check your fluid level... your sig states you have a separated system. By end of summer, I hope to have survived this, and will have the new Speedriven/Rudy system in the cars...
You can add a header tank and inspect the fluid level, but how would you add a low fluid sensor? Adding a sensor to the header tank would be pointless.
Old Feb 22, 2013 | 04:27 PM
Bigkid's Avatar
Me too Doc. Rudy's stuff ordered.
Old Feb 22, 2013 | 05:00 PM
An ole' engineer yourself 180 you should know....a float gauge in the tank, wired to a simple red LED light where ever you would like to see it... same set up I will have in my meth tank once installed...
Old Feb 22, 2013 | 05:32 PM
Float gauges are OK but in situations where there is movement the gauge has to be damped or you keep having a flashing light. The float signal in the WW tank is damped somehow. When it trips it stays tripped.
I think the tank is best, you look and if it's down you start to worry.
Old Feb 22, 2013 | 09:40 PM
dinasrt's Avatar
Like this 180.
Old Feb 22, 2013 | 09:48 PM
Originally Posted by dinasrt
Like this 180.
Cool, what is it made from? Does it have a cap or does it go commando like Woody recommends?
Old Feb 22, 2013 | 09:57 PM
dinasrt's Avatar
Dave, when you click on that thumbnail pic., there are a few other pic.'s above it in the gallery display. If not, they are in my gallery. That little tank is a power steering reservoir off a BMW. They are very inexpensive and can be gotten on E-Bay. Beaner said that if you bring it to him, he can install it for you.
Edit: Sorry for the threadjack Tebow.
TerryR
Dec 13, 2019 03:27 PM
Sep 28, 2015 07:40 PM
Billto
Sep 28, 2015 12:05 PM
gblack32
Sep 26, 2015 10:00 PM
ozkancab
Sep 25, 2015 10:55 AM
