Headers, I mean jewelry, arrived
Re: Headers, I mean jewelry, arrived
they do look pretty Les, I would look into thermal coating them instead of wrapping them myself as the wrap will eat up clearances or can come undone. let me know what you decide on the downpipes. we can set you up with the back half of some downpipes so you wouldn't need to hack up yours.
Les
There is a place near where I live that does high performance coatings for stuff for Corky Bell. They did a set of full length headers for my dad's '67 GTO, they looked incredible. here's their website; Cradin Industries - Boerne, TX - Coatings
No excuses, We need info ASAP!
It looks like I should have kept my mouth shut. Problems from the start. The dyno numbers came in weak, not that I care, but then I found a puddle under the car. It seems the meth hose melted or otherwise was compromised so ..... they're fabricating a metal line and hopefully will do another dyno afterwards to get "how I run the car" numbers. It really doesn't matter except the tune is lean without the water/meth. But for those interested, 336 hp with who knows what the problem is, where it's too hot to touch for a while. I don't think the car will be finished until ..... I'm not even going to guesstimate. Booooooo!
Les
Les
Les
Les
The shop still hasn't called so I assume ....... no, I'll be going to take a look tomorrow. They didn't put the car on the lift until Thursday afternoon and I don't know their workload. They're doing the instal cheap but I figured once the car was on the lift they'd knock it out fast. An occupied lift is money tied up and other work that waits. They've always done a professional job for me and ya know, that's worth a lot, even if they take forever. No one is more curious than me. If cane liquor wasn't so cheap I'd be without sleeping all week. See the state I'm in? I can't put two sentences together.
Les
Les
Went by the shop, the headers are on. Now they're putting on all the parts that had to be removed or loosened and moved out of the way. They had to lift the engine and loosen the steering box. We discussed the exhaust connections, in stainless naturally, which is Monday's problem I'm afraid. I requested a dyno with the open headers, should be exciting. If I could only be there when they do it. After the new midsection is fabricated and connected to the stock slip joints before the resonator, another dyno. Good information on the how the stock cat back flows should come out of my little project. The waiting is excruciating fellows, but oh the the things were going to learn.
Les
Les
Thanks for the info, Wes. Seems that emission controls over here in germany are more restrictive than in your country. If we use 200 cel metal catalysators for the primary cats and use the stock secopndary cats we have a change to pass emission tests. If we use 100 cell cats primary and stock cats secondary we can't pass. So no header conversion for all guys from germany with these headers.
Regards
Markus
Regards
Markus
