...HELP...how do I put on the belt???
It was.. neither one of those guys in the first picture are you. Or were you just being nice and letting them sit in the car..
Jenny Craig? Maybe I was wrong..
Thats not me in this pic.i was done with you months ago. Grow up a little.
Funny guy. That was from 2007. Have a better look at the hood vinyls.. nice try lil man
You'll need a 17mm socket and a breaker bar. Remove the air cleaner box and you can access the belt tensioner easier. Turn the 17mm bolt ( sits around the 8 o'clock position) counter clock wise and remove the old belt. If you don't have a diagram,draw one before you replace the belt !! If you don't have a breaker bar a short pipe on a socket wrench will do.It will take a little coaxing but you'll do fine. Make sure the belt is on all the pulleys and you're done !!
