rough running
Old Oct 26, 2017 | 03:01 PM
deltacrossfirebob's Avatar
Default Re: rough running
UPDATE
First a great thanks to all the advice I received here.
After espresso this morning went to task
Would not do a normal start but by pushing gas to floor and easing up while running had a rough idle around 500 rpm
Slowly smoothed out
Popped off air filter and shot the MAF sensor with a couple of quick blasts of CRC MAF cleaner Waited a few seconds and shot the sensor with some canned air.
Running great.
Gonna go do a throttle reset.
Black Friday wish list for Rob @ Needswings.....fuel filter, oil filters, and plugs
Thanks again for info
Old Oct 26, 2017 | 04:28 PM
Padgett's Avatar
Good to hear it and lear something every day. For me it usually takes three or four CRC spray cleanings over a week or so before I give up and buy a new MAF sensor.
Old Oct 26, 2017 | 11:18 PM
dinasrt's Avatar
High mileage vehicles may see performance improvement with an injector service/cleaning, especially after spraying cleaners designed to break loose the crud. This is the service provider I went with recommended by a few others here on the forum.
https://www.crossfireforum.org/forum...1&d=1509074218
Old Oct 28, 2017 | 12:42 PM
dinasrt, thanks for the extra info
Will look into them.
Are you here in Brentwood??
Old Oct 28, 2017 | 01:02 PM
dinasrt's Avatar
Am putting off till mid week. Will send you a PM when down there; perhaps get together for a short drive? I was glad to see that you were able to clear up the rough running.
Old Oct 28, 2017 | 01:09 PM
Sounds great
Wednesday and Thursday I have to be in Sacramento for Delta Stewardship meetings
Looking forward
GRANDPA
