View Poll Results: Do you want to have a turbo in your naturally aspirated Crossfire?
Definitely, give me the single-turbo set-up!
29.85%
Yes, but twin turbo's would suit me best!
55.22%
No thanks, I am happy with the Crossfire's power output as-is
14.93%
Voters: 67. You may not vote on this poll
Twin Turbo kit
Old Aug 2, 2005 | 03:44 PM
EUROREV's Avatar
Default Re: Twin Turbo kit
if its a single turbo kit, it doesn't mean its spools quickly. it depends on the trim on the impeller side.
however, there a reason why people go single turbo,it is big power. that's what they are after, they are not concerned per say with drivability of the car. that's why turbo supras and skyline that want 1000 horsepower, go to single turbo. example why porsche went from 930 single turbo to 993 and 996 twin all in the name of drivability. if anyone of you have ever drove a 930 turbo you will understand what I mean. when you first take off, there is no power but mind you as soon as that turbo kicks in, make sure your straight if not you will be spinning. also do a search on turbo and boost, matter of fact pick up the book called Maximum Boost by Corky Bell, its explains how more psi is not always the answer.
Old Aug 2, 2005 | 03:54 PM
EUROREV's Avatar
Also twin turbo setups usually spool quicker since they are usually smaller turbos.
Old Aug 2, 2005 | 04:12 PM
respdoc's Avatar
Originally Posted by golfdude
400 hp is nice in the SRT-6, but it is still an automatic.
This "it's an auto" nonsense is getting quite old. With the current times for new SLK V-6's posting a .1 second better 0-60 times with a stick over the autoshift this view has no backing.
Only reason I have ever heard that made an ounce of sense of one over the other was the fact the owner preferred the "feel" of the stick to the auto. I 100% agree to that but since this car (SRT-6) doesn't have the option of a pure stick there's no rational reasoning for custom fabbing a manual transmission to the car.
So if your looking at straight performance, the guy with the manual can "feel" his car all day long but this will not change the fact that the guy with the autostick will walk away the winner every time given that the autostick guy used his mod budget on some real power mods while the manual guy got his "stick"...
Old Aug 2, 2005 | 11:46 PM
golfdude's Avatar
In drag racing, the automatic becomes man's best friend...it's consistent, has the ability to always shift at redline, and it can shift faster than any human can. But, I am not too fond about the automatic transmission simply because they make the driving experience less involving. Plus, only few things are more satisfying than hearing the blip of the throttle and a perfectly executed downshift. People may argue that autostick feature of the SRT-6 does the same thing, but having the clutch there makes the downshift that much more satisfying.
Old Aug 3, 2005 | 03:53 PM
x'ed's Avatar
maybe in high horsepower situations, and we are talking custom auto trannies, not stock ones. manuals from the factory almost always rev higher and can be shifted much faster than an auto, and eurorev, thanks for saving me from having to make the same statement about tt's spooling faster.
Old Aug 3, 2005 | 04:17 PM
respdoc's Avatar
Cold hard facts though is that Mercedes does not have a performance many that can used in the SRT/SLK32 setup. So any transmission used would have to be custom fabbed job that would take mucho time and mucho money and would provide little gains over the autostick unless your plans are to transform the car into a full-spec'd racer...
smfrycruzr
Jul 17, 2023 05:33 PM
amx1397
Other Vehicles
Jul 24, 2020 09:25 AM
zackman62
Nov 6, 2015 12:37 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
