Fuel hose replacement A1074701075
Old Oct 22, 2024 | 01:14 PM
AK Roadster's Avatar
Default Fuel hose replacement A1704701075
Happy day xf friends! I am looking for a fuel line part A1704701075 from MB. Does anyone know where to find a replacement? It is a high-pressure fuel hose with fittings on both ends from the engine to the top of the fuel rail. Looking forward to hearing back and thanks to everyone participating.
Fire Hazard: Friends please check your fuel line for a spongy soft spot in the middle of the line. A wide swath of fuel was spraying on the ground, when I backed out of the garage. The fuel hose had split lengthwise spraying atomized gas everywhere under the hood. Crazy, that the engine never sputtered a bit.. See photo below for location.
Grateful, to report no disaster! It would have been really inconvenient to have this problem on the road-trip I took from Alaska to Washington. My '05 Roadster has just over 35K miles on the odometer and I try to stay away from ethanol gas if I can.
Thanks to my new friends at "NeedsWings!" for stocking a new COH, made in Germany, fuel line part and sent it via USPS. It was only four days time to arrive on Hawaii Island and the fuel line was easily replaced with a 14mm and a 17mm wrench.
Thanks to M60A3Driver for locating the part replacement. Also a great idea from another forum member, for suggesting local wrecking yards for parts availability..
Aloha.
Fuel line split in the middle.
Last edited by AK Roadster; Dec 29, 2024 at 03:02 PM. Reason: Part number correction A1704701075
Old Oct 22, 2024 | 05:11 PM
Default Re: Fuel hose replacement A1074701075
Where did you get that number?
Old Oct 23, 2024 | 12:07 AM
Default Re: Fuel hose replacement A1704701075
Originally Posted by AK Roadster
Happy day xf friends. I am looking for this part A 1704701075 from MB. Does anyone know where to find a replacement? It’s a high pressure fuel hose with fittings on both ends from the engine to the top of the fuel rail. Looking forward to hearing back and thanks to everyone participating.
Needswings has it:
Fuel line
rmcdaniel12
Jan 29, 2016 09:45 PM
crymar
Jul 17, 2015 08:46 AM
crymar
Feb 16, 2015 06:18 PM
boostmonkey
Apr 28, 2014 05:35 PM
JesseJamessrt6
Dec 2, 2013 09:41 AM
