Europe Serving all countries of the European continent.
Engine management light no fault?
Old Oct 10, 2014 | 09:36 AM
yorkiekev's Avatar
Default Engine management light no fault?
First of all hello, this is my first post, recently bought a 53 crossfire, got a query, initially the engine management light came on and the code indicated that the airflow meter sensor (by the battery) was at fault, that has now been cleared/fixed but I still have an engine management light on, the reader reads no faults so there is nothing to reset....any ideas? I know it may clear if I remove the negative battery lead, which I have done but it pops back up again !
car runs well, no apparent problems, and just been serviced
Many Thanks
Old Oct 10, 2014 | 11:06 AM
Default Re: Engine management light no fault?
If the CEL keeps coming on, and your reader shows no faults, then you need another ( better ) reader.
I highly doubt the light is on with no faults, but I may be wrong.
Old Oct 10, 2014 | 06:02 PM
Toolman's Avatar
A more advanced OBDII scanner will pick up more detailed manufacturer specific error codes. Even then they don't pick them all up, and it may be necessary to take it to a dealer or independent that has a DRBIII scanner.
Old Oct 11, 2014 | 10:01 AM
Is it an engine management light or one of the other lights? Like the one that says you have "light" out? There are several indicators like this. Just checking....
Old Oct 12, 2014 | 02:07 PM
yorkiekev's Avatar
ok thanks, well will be taking it back to the car dealer i bought it from this week, will check out their reader ....car runs fine...but thanks for the replies, will update when i get it checked
Old Oct 13, 2014 | 10:03 AM
robby363's Avatar
A bad gas cap can cause light to come on and reset and clear the code after a little driving.
Old Oct 13, 2014 | 12:51 PM
yorkiekev's Avatar
Mmm really? may sound stupid in what way? does it affect the flow of fuel to the engine and how would i spot a duff cap?
Many thanks
Old Oct 13, 2014 | 01:33 PM
robby363's Avatar
Many thanks
If the cap isn't sealing right it can cause the EVAP system to throw codes till the system reaches the proper pressure. You can't tell by looking at the cap if it's bad you would probably have to pressure test it to tell. I'm not saying that's the problem I'm just saying it could be a possible cause of the CEL light with no codes.
Old Oct 14, 2014 | 01:29 PM
yorkiekev's Avatar
ok that's great, got to be checked even if to discount it so thanks for the info
Old Oct 21, 2014 | 11:52 AM
yorkiekev's Avatar
Many Thanks
Just an update ...think it it has been cracked, found a great local garage who has the correct equipment for Chrysler and the fault was diagnosed as an air leak....a few checks round the engine bay and seems to now be cleared, although having it in for a good check as a matter of course so good news...thanks eveyone for your inputs though
massanu
Feb 20, 2019 07:06 PM
jgreen
106
Sep 18, 2017 11:46 PM
wruss
Feb 8, 2017 01:05 PM
northwest_crossfire
May 30, 2016 05:19 PM
Ralph289
Jul 26, 2015 12:52 PM
