Interior lighting dim on AC/Heat panel
Old Sep 8, 2006 | 08:59 AM
Rickyms's Avatar
Default Interior lighting dim on AC/Heat panel
Is there a separate way to increase the brightness of the lighting around the AC/Heat controls? They are very dim, it does not matter how bright in increase the **** on next to the speedo. If this is normal please let me know
Old Sep 8, 2006 | 09:45 AM
former NXMX5's Avatar
Default Re: Interior lighting dim on AC/Heat panel
they should follow the gauge adjustment ****, but they seem to be on some kind of delay, so they take about an extra half a second or so to adjust while the gauges will dim or brighten in 'real time'.
make your dimmer full low, wait 5 seconds, then make it full high. did the heater controls change? if not, you have a problem.
Old Sep 13, 2006 | 10:21 AM
MAYAman's Avatar
I can't even figure out how to increase the brightness. How do you do it?
Old Sep 13, 2006 | 11:02 AM
rotate the odometer reset ****.
pioneer4x4
Jul 1, 2021 10:56 AM
PNA
Nov 12, 2020 04:44 PM
pioneer4x4
Mar 25, 2019 10:35 AM
Hoppy
Dec 7, 2018 07:36 AM
rocketrage
Oct 7, 2015 05:00 PM
