Headlight corrosion/fogging
Old Mar 31, 2007 | 12:00 PM
Jl2row's Avatar
Default Headlight corrosion/fogging
Does anyone experience corrosion or fogging to the plastic headlight casing? The plastic on my driver's side headlight looks as if some acid had been spilled in it melting the plastic (this is not the case...it is just wearing) and the casing is beginning to fog. I went to the dealer and they said that it is not a defect...BS!!! it is a defect since it is only two years new and it is not normal wear and tear on the car. The factory rep is coming out to look at it and it would help if I can prove others have this problem. Thanks for anyone's help.
Old Mar 31, 2007 | 02:00 PM
CrossfireLTD's Avatar
Old Mar 31, 2007 | 08:09 PM
Iamfink2's Avatar
Default Re: Headlight corrosion/fogging
Mine did the same thing and the dealer replaced both headlights under warranty.
smfrycruzr
Jul 17, 2023 05:33 PM
srtmodder
Aug 23, 2017 08:28 PM
Franc Rauscher
May 9, 2016 12:04 PM
gp1200x
Dec 6, 2015 12:59 PM
RacerXofFL
Sep 15, 2015 05:00 PM
