LED Bulbs for the Glove Box, Trunk, Dome and License Plate lights
Old Aug 25, 2007 | 07:58 PM
DanielNTX's Avatar
Default LED Bulbs for the Glove Box, Trunk, Dome and License Plate lights
So I got replacement LED lights on the recommendation of the forums from http://superlumination.com/ but there are many different styles of 194 and feston bulbs.
This is what I recommend for each area:
Glove Box and License Plate lights: 36mm = 1-3/8" Long 4LED
Trunk: 44mm = 1-3/4" Long 9LED (I'm pretty sure the fetson 44mm Super High-Flux Leds dome bulb with the 2 LED's would work as well)
Dome Light: 194 Superstar Bulbs (I almost choose the 194 5LED Matrix Bulbs because i thought it would have better dispersion, but from the pictures it looked brighter.)
Old Aug 26, 2007 | 03:43 PM
SRT-6'er's Avatar
Default Re: LED Bulbs for the Glove Box, Trunk, Dome and License Plate lights
What color LED did you get? Any pics?
I plan to do the same w/ blue LED dome/cargo lights (I have a SSB SRT-6)...
Old Aug 30, 2007 | 05:50 PM
Steve Hellums's Avatar
I done the LED's in hyper white in the dome, hatch and license plate lights. They have a blue tint to them and they look real good on the aero blue. I also done the same to the clear side marker lights, (front & rear) and parking lights.
Old Aug 30, 2007 | 06:24 PM
Sidez's Avatar
trunk is not 44mm... it is more like 39... I have done this as well and when I purchased the 44 it BARELY FIT and it stands crooked...
other than that I have done this as well in green to match the dash color...
Old Sep 18, 2007 | 01:26 AM
DanielNTX's Avatar
Sorry it took so long for the pics, but they are here in this thread: My red Crossfire is actually blue!!!
Old Sep 18, 2007 | 07:51 AM
Cincinnati Slim's Avatar
Did you need any load resistors for the LEDs to prevent a "Lamp Out" indicator on the dash ?
I like the low power drain of the LEDs. I switched my little MagLight to LEDs and my batteries seem to last forever now...
Slim
Old Sep 18, 2007 | 08:00 AM
DanielNTX's Avatar
No load resistors.
Old Sep 18, 2007 | 02:48 PM
MMZ_TimeLord's Avatar
You should only need load resistors if you change exterior bulbs, such as the License plate marker lights.
Otherwise the "lamp out" indicator will stay lit.
Old Sep 27, 2007 | 08:15 AM
uniquemethodz's Avatar
Your car looks awesome! I want to do the same but in green. Do you know a good place to get the bulbs and also I want to get those pearl white HID headlight bulbs. Any recommendations?
Old Feb 9, 2008 | 11:21 AM
AtlantaSRT6's Avatar
Smile Re: LED Bulbs for the Glove Box, Trunk, Dome and License Plate lights
Just a follow up that the above noted sizes worked fine on my 2005 SRT6 Coupe. Here is what I installed and paid for each bulb from
http://www.superbrightleds.com/
DOME: WLED-WHP Pure White High Power LED (one of many 194 replacement options) $4.95 x 2
GLOVE BOX: 3610-x4 LED 36mm Festoon White 3610-W4 , $2.84 x1
Boot/Trunk: 4410-x9 LED 44mm Festoon bulb Cool White 4410-CW9, $4.74 x1
SuperbrightLEDs charged $5.00 for shipping & handling so my total cost was $22.48
A few notes:
In the boot- I believe a 42mm Festoom would have fit fine (in fact I think that is what was in the fixture). And since 42mm Festoons are available in BRIGHTER styles I may change that out, but I'm going to give this one a try for awhile and see how I like it.
In the dome- The WLED-WHP Pure Whites are GREAT! Very bright, much nicer than the original bulbs.
Cheers
Old Feb 9, 2008 | 11:34 AM
Utah12's Avatar
I used 44 mm for the cargo area and it was actually a little short. There must be a couple of different arrangements. Did you remove those little heat shield/reflectors from your dome fixture?
Old Feb 9, 2008 | 03:07 PM
I re-installed the heat shield reflectors with the LED lamps. I think they help spread the light pattern out and make it a little more diffuse. But, it wasn't dark when I did it (today) so I haven't tried them both in and out to see which way I like better. If I remember I'll post my result after trying it BOTH ways.
Old Feb 19, 2008 | 09:27 PM
downwardspiral's Avatar
I think he changed the license plate lights..?! I'm going to change over my LP and dome lights to leds because I love the look of it.
Old Feb 19, 2008 | 10:32 PM
Utah12's Avatar
Are resistors necessary for the License Plate lights? I have heard yes and no. Can someone post a "how to do" on the installation of resistors with the LEDS.
Old Feb 20, 2008 | 05:43 AM
I ordered the LP and dome LEDs yesterday, and I ordered a resistor just in case (i dont know if i need 2) but it seems like the hardest part of wiring one in is finding a spot to put it. I guess it all comes down to the draw on the bulb. Being that the LP lights are in the hatch door, it may need to go more towards the fuse box. I didnt check yet, but if there is a fuse for the LP lights, ill put it right before the box.
Old Sep 6, 2008 | 10:01 AM
brazilian177's Avatar
Talking Re: LED Bulbs for the Glove Box, Trunk, Dome and License Plate lights
A few notes:
Cheers
HEY just ordered mine from superbrightleds.com and i also ordered bulbs for the headlight the 194 wedge bulbs all bulbs were ordered in white i currently have blue dome lights and blue LED headlight corner bulbs will post new pics when i receive it in a week or so thanks for the info guys!
here is my shopping list
Quantity Product Price Base Shipping Options Subtotal 1 WLED-WHP Pure White High Power $ 4.95 $ 0.00 $ 4.95 1 4211-x6 LED Festoon bulb $ 1.95 $ 0.00 Cool White 4211-CW6 1.75
$ 3.70 1 WLED-WHP Pure White High Power $ 4.95 $ 0.00 $ 4.95 1 3610-x4 LED Festoon bulb $ 1.89 $ 0.00 Cool White 3610-CW4 0.95
$ 2.84 2 T13-x6 Wedge Base LED bulb $ 1.99 $ 0.00 White T13-W6 1.00
$ 5.98
Subtotal: $ 22.42 Shipping: $ 5.00 (estimated) Grand Total: $ 27.42
Old Sep 6, 2008 | 10:09 AM
SRT-6 Steve's Avatar
$ 5.98
For all interior lights, no issues and do not have to install resistors?
Steve
Old Sep 8, 2008 | 04:04 AM
amcordo's Avatar
You may into some issues with flickering/failing LEDs down the road as a result of under/over voltage. You'll want to get a voltage regulator to install at every interior lamp location (as well as the license plate lamps if you're doing the exterior) to prevent this in the future. Visit this thread and read the part on the first post about the license plate lamps to find a link to a good regulator:
https://www.crossfireforum.org/forum...ad.php?t=21839
Old Oct 19, 2008 | 01:54 PM
Angry Re: LED Bulbs for the Glove Box, Trunk, Dome and License Plate lights
man i wish i had seen this before my leds are out already and look when i posted i had bought them and installed a week after my post and now 1 187 corner led is out and the other is flickering and the trunk led flickered for a day now its normal....im mad cuz i paid 30 something for LEDS and they are out already!!!! AHHHHH!!!!
Old Mar 22, 2011 | 04:45 PM
srt666's Avatar
So the license plate lights are 37mm?
