passenger headlight
Old Dec 31, 2007 | 12:09 PM
manisusmc's Avatar
Default passenger headlight
What's the deal with the passenger headlights, does the coolant reservoir need to be removed/detached to change the bulbs. I've tried to wiggle them off with needle nose pliers.
also what is the easist way to change the small 194 light bulbs
Old Dec 31, 2007 | 03:58 PM
robby363's Avatar
Default Re: passenger headlight
I changed mine without moving the reservoir. It's a pain in the *** so you might want move it enough to get your hands in there. I used needle nose pliers to pull connecter off. If it's the first time being changed the connecter is tuff to get off but just wiggle and pull at same time and it will come off. That's the easy part getting the bulb out and back in is even more fun so if you don't have a lot of patience you might want to move the reservoir.
Old Dec 31, 2007 | 07:48 PM
woodlands1's Avatar
It helps to use a pair of the ninety degree bend needle nose pliers to change out the 194 bulbs. You can get leverage that is very difficult otherwise.
55chevy
Jul 22, 2024 02:31 PM
smfrycruzr
Jul 17, 2023 05:33 PM
Billy22Bob
Oct 1, 2015 05:34 AM
Charlesl
Sep 30, 2015 10:46 PM
Posimoto
Sep 13, 2015 06:13 PM
