headlight tint
Old Apr 8, 2008 | 08:09 AM
HyprLtH20's Avatar
www.CustomCrossfire.com
Default Re: headlight tint
Originally Posted by jonnyangel04
I have a graphite crossfire so i went with the lighter tint and it matches perfectly. I would suggest taking the lights off its much easier to work with and looks much better. LOL since you have to take the bumper off, to get to the lights, you might as well kill as many birds possible with one stone. If you have an SRT6 go new pump, maybe a heat exchanger, Hid kit is much easier to put it with lights off, Hid fog lights, The list could go on and on but you get the idea.
You do not have to take off the bumper to get them off.. inside the front wheel well there is a panel that simply pops off and exposes the inside of the bumper. from there you can take off the fog lights and the lower 2 screws of the headlights. you might have to take the wheel off to get your hands in there however. also, for a lot more visability..... pop of the side marker with a flathead screwdriver. you can see exactly what your doing instead of just feeling around in there!
Old Apr 21, 2008 | 01:42 PM
skrzypekusmc's Avatar
I used an 8% "Iron" colored tint from www.stickercity.com and it looks great. It's a pretty light tint and doesn't affect the light output. The kit was about a 1/2 in too wide all the way around but an xacto knife made short work of the issue. I did take out the foglamps to tint those and am re-installing them tonight. I'll take pictures after it's done. I also had a slight problem with air bubbles on the headlights but it was due to my lack of following directions. If you heat up the headlight and the tint before you apply them then the bubbles should be minimal and evaporate within a week. I had to pop mine with a pin but it is hardly noticeable. Anyway, I'd consider sticker city if anyone is shopping around. They also offer the film in yellow, blue, clear, and darker tints.
Old Apr 21, 2008 | 08:23 PM
Thumper SRT6's Avatar
Originally Posted by midnightman
I've been curious about headlight tints. I've tried searching the web to see what is and isn't legal in Florida and haven't been able to come up with the answer. I was thinking a blue or light smoke tint would look good. If anyone knows what's legal, please tell me.
I've been curious about this myself. I found this page: http://www.port-orange.org/police/faq.htm. I also found the State of Florida website. Here the link for 2007 Florida Statutes, MOTOR VEHICLES CHAPTER 316 STATE UNIFORM TRAFFIC CONTROL
Here is the answer, right at the top of the Port Orange page (Note that I linked to the actual Statutes referenced below):
Headlight Covers - F.S. 316.220 states, "An object, material, or covering that alters the headlamp's light color may not be placed, displayed, installed, affixed, or applied over a headlamp." A similar statute also prohibits the use of such devices on taillamps, if the device alters the taillamp's visibility from 1,000 feet away (F.S. 316.221).
Clear Taillamp Covers - Under F.S. 316.241 above, it is illegal to alter the taillamp assembly by replacing the clear bulb and red lens with a red bulb and clear lens.
Also on the same page, window tint:
Side windows (F.S. 316.2953): A person shall not operate any motor vehicle on any public highway, road, or street on which vehicle the side wings and side windows on either side forward of or adjacent to the operator's seat are composed of, covered by, or treated with any sunscreening material or other product or covering which has the effect of making the window nontransparent or which would alter the window's color, increase its reflectivity, or reduce its light transmittance. A sunscreening material is authorized for such window if, when applied to and tested on the glass of such windows on the specific motor vehicle, the material has a total solar reflectance of visible light of not more than 25 percent as measured on the nonfilm side and a light transmittance of at least 28 percent in the visible light range. Violation of this section is a noncriminal traffic infraction, punishable as a nonmoving violation.
Windows behind the driver (F.S. 316.2954): Same general provisions as side windows, except that a sunscreening material is authorized for such window if, when applied to and tested on the glass of such windows on the specific motor vehicle, the material has a total solar reflectance of visible light of not more than 35 percent as measured on the nonfilm side and a light transmittance of at least 15 percent in the visible light range.
Enjoy!
smfrycruzr
Jul 17, 2023 05:33 PM
xfireohio
Jul 20, 2020 12:03 AM
srtmodder
Aug 23, 2017 08:28 PM
Franc Rauscher
May 9, 2016 12:04 PM
RacerXofFL
Sep 15, 2015 05:00 PM
