05' Turn Signal Bulb Housing
Old Aug 27, 2009 | 08:30 PM
liljay's Avatar
Default 05' Turn Signal Bulb Housing
I have 05' xfire and I was having intermittent front turn signal failure. I replace the bulb on the left and right side at the same. The next day the drivers side bulb failed again. I suspected a short somewhere hoping it would be with the wiring on the bulb housing. My bad there is no wiring on the turn signal housing. Upon closer inspection, I found the leads or contacts on the housing themselves had eroded. Now I in the market for replacement bulb housing. I will start at the dealership, ebay, mopar parts online and finally I will just replacement the headlight assemblies. Any help or suggestions would be most appreciated.
I have the PDF that lists all the crossfire part numbers, but can not find the part number I believe the part to be.
Old Aug 27, 2009 | 08:37 PM
GDC-SRT's Avatar
Default Re: 05' Turn Signal Bulb Housing
Welcome to the forum.
I cannot help with the headlight problem, though someone here may have one or two headlights lying around. The entire assembly is sort of pricey new.
Where did you find the pdf parts list? that could be real handy.
Old Oct 13, 2009 | 09:18 PM
Thomas B. Whyle's Avatar
Your Chysler dealer parts man is either lazy or stupid, or both. My dealer's parts man walked back and picked one off the parts shelf as soon as I asked. The part number is 1-5174703AA, and the price is $21.84. To replace the whole headlight would be ridiculous. TBW
skeet370
29
Sep 18, 2015 05:53 AM
lazorouss
Sep 11, 2015 09:16 AM
BEATv1
Sep 10, 2015 12:58 PM
rdougc
Sep 5, 2015 10:30 PM
maxcichon
Sep 4, 2015 12:50 PM
