My H7 bulb headlight saga
Old Jan 24, 2024 | 12:40 AM
JSK's Avatar
JSK
Default Re: My H7 bulb headlight saga
Gary, it looks like you might be in my neck of the woods.
Old Jan 24, 2024 | 01:07 PM
Yup I was.....rented a house in Chandler....saw family in Queen Creek...saw friends in Mesa and Phoenix and visited Sedona, AZ - My pics here
Old Jan 25, 2024 | 01:21 AM
JSK's Avatar
JSK
Yup, you were right in my backyard. Wish I had known you were here.
Old Jan 25, 2024 | 07:11 AM
I was there with my wife to see family and some friends.
Never thought to post my arrival here to see if there were any Crossfire owners to meet while there.
Old Jan 25, 2024 | 08:27 AM
Really great pictures of your road trip & visit. Thanks for sharing - I really enjoyed going thru the album.
Later,
Old Mar 8, 2024 | 11:36 PM
Mike G's Avatar
My first time changing and couldnt see how the damn clip worked (it came out when I removed the bulb).
Thanks to this post, grabbed a mirror and hey presto, answer was right in front of me :-)
Old May 18, 2024 | 08:24 PM
Oldschool's Avatar
deleted
Old May 21, 2024 | 12:48 PM
LLzel's Avatar
since the post has been resurrected, I would like to change my low and high beams, not so bright at night. What are folks installing?
Old May 21, 2024 | 07:43 PM
I just installed Lasfit H7 LEDs in my car. What a difference! It's the same bulb for low and high beams.
These are the ones I used. They're Can Bus error free and have fans in them to keep them cool.
Lasfit H7 Lasfit H7
Old May 21, 2024 | 09:10 PM
LLzel's Avatar
Thank you for the response I’ll order them!
Old May 22, 2024 | 01:28 AM
JSK's Avatar
JSK
Lasfit H7
I put them in the low beams only in one of my cars, my concern about high beams is how quickly they come on. Any delay?
Old May 22, 2024 | 01:33 AM
I didn't notice any delay. I can check tomorrow and let you know for sure.
Old May 22, 2024 | 12:05 PM
JSK's Avatar
JSK
Appreciate it.
Old May 22, 2024 | 03:29 PM
Nelson G's Avatar
I used Lastfit H7 LED Bulbs 50W which worked well. And I used 9006 LED Bulbs Fog Light 60W for the fog lights. I eventually replaced all the bulbs with LastFit LEDs. They work well and are very bright. I was most worried about the stoplights so I wanted something brighter than the standardbulb. The marker lights look better with the LEDs.
Old May 22, 2024 | 03:42 PM
LLzel's Avatar
I too would like to replace all of them. If not to bother you too much, can you post the model numbers for the other Lastfit bulbs? Running, fog, marker, tail lights and reverse lights. Did I miss any? H7's were delivered today so that will be my weekend project.
Thanks
Old May 22, 2024 | 04:07 PM
Nelson G's Avatar
Here is what I purchased. I will tell you I used clear lights for the marker lights because they look better than when I purchased the amber and red ones. The trunk light is different than the glove box light even though LastFit said it was the same. This is the thing I found out in buying the bulbs because the car is 3/4 Mercedes and 1/4 Chrysler some of the light fixtures are not the same as stated.
I did not use Amazon but purchased from LastFit they were very helpful and when something did not work out they replaced it at no cost. Can't beat great customer service and the cost was the same.
I will say I occasionally get a bulb-out signal (backing up) but after driving a while it goes away. I have not had any other problems and I am very happy with the LastFit LEDs. At night they light up the road, I live in a rural area and I am old so they work well for me.
And don't forget the headlights have a certain way that the tab needs to be put depending on if they are used for the headlights or the high beams. So watch this video:
Also, there is a way to replace the small marker lights in the headlight compartment. Here is the link: https://www.crossfireforum.org/forum...t-cluster.html
I hope this helps you. Take your time and you will be very happy with the results. I am.
9006 LED Bulbs Fog Light 60W 6000LM 6000K | LCair Series, All-in-One Design × 1
H7 LED Bulbs 50W 5000LM 6000K | LCair Series, All-in-One Design × 2
1157 2057 2357 7528 Red CanBus LED Bulbs Turn Signal Brake Tail Lights | Error Free Anti Hyper Flash, T3 Series Upgraded Version × 1
1156 1073 7506 1141 LED Reverse Backup Light Bulb | Xenon White, 2 Bulbs × 1
BAU15S PY21W 12496 CANBUS Error Free Anti Hyper Flash LED Turn Signal Lights | Amber Yellow, 2 Bulbs × 2
8 Colors License Plate Dome Map Side Marker T10/ 168/ 194 Bulbs | CANBUS Error Free, 1 Pair × 2
168 194 2825 T10 CANBUS Error Free LED Side Marker Lights Dome Map Bulbs | Amber, 2 Bulbs × 1
T10 194 168 CANBUS Error Free LED License Plate Dome Map Trunk Cargo Light Bulbs | White × 1
36MM 6418 6411 DE3423 LED Dome Map Trunk License Plate Light Bulb, 2 Bulbs × 1
39MM DE3425 6461 LED Dome Map Courtesy Trunk Light Bulb, 2 Bulbs × 1
Old May 22, 2024 | 08:11 PM
I tried my high beams today and there was no delay.
Old May 23, 2024 | 01:39 PM
  #38 (permalink)
JSK's Avatar
JSK
Thanks, appreciate you checking and replying.
Old May 23, 2024 | 09:03 PM
  #39 (permalink)
LLzel's Avatar
Thanks for all the input. My Memorial Day weekend will consist of changing all the lamps except the side marker lights.
Old May 23, 2024 | 11:59 PM
  #40 (permalink)
No problem.
