HELP!! Lights dont blink
Old Jan 2, 2010 | 01:00 AM
murtazanooruddin's Avatar
Question HELP!! Lights dont blink
05 crossfire. you know how when u lock or unlock the car both the right and the left flashers flash twice well mine used to also but now it only flashes on one side wether im locking or unlocking . i was wondering if nyone else is having that problem and if so how to fix it?
thanks
Old Jan 2, 2010 | 09:07 AM
MikeR's Avatar
Default Re: HELP!! Lights dont blink
My first thoughts would be to check the bulbs first and see if you have one out. Then check the fuses. There are fuses for left and right side.
Old Aug 18, 2010 | 10:28 PM
rekcah's Avatar
any update on this problem? I'm having the same issue. When I press lock, sometimes both left and right same blinks then sometimes only the right side blinks.
Old Aug 19, 2010 | 07:51 AM
Phil's Avatar
Guys,
i have a similiar problem. My left drivers side front turn signal doesn't work. On the dash, it gives me a fast flash rather than the standard. I have replaced the bulb, which did not fix it. When it first started to happen, it was an intermittent problem. Now it's all the time. I've checked the fuse and it looks good. Any help would be appreciated. My car is a 2005 coupe.
Thanks ...
Old Aug 19, 2010 | 04:09 PM
rekcah's Avatar
i've posted a youtube video of the problem
YouTube - Lights dont blink
Fuse, bulb and battery replaced with no luck. What module controls the blinking of the blinkers when the lock/unlock buttons are pressed?
When using the turn signal it lights up just fine.
Old Aug 19, 2010 | 04:22 PM
Check the level of your blinker fluid.
We recommend "BLINKY" brand blinker fuid.
I use it in all my cars.
Old Aug 19, 2010 | 04:37 PM
rekcah's Avatar
Should I make sure that the Blinky Blinker Fluid is Synthetic?
Should I get some Elbow Grease with it too?
Old Aug 19, 2010 | 04:44 PM
From the repair manual.
OPERATION
The Sentry Key Remote Entry Module (SKREEM) has the following functions: receiving and evaluating the Radio Frequency (RF) keyless entry remote signal, actuation of door locks in conjunction with the Central Locking Pump/Security System Module, and enabling the vehicle theft security alarm with confirmation via the turn signals. When the RKE transmitter is operated, an RF signal is transmitted. If the SKREEM recognizes the RF signal as valid, it actuates the Central Locking Pump/Security System Module through the Body Control Module. The vehicle is then locked or unlocked through the power locks system. Connected to the SKREEM is a Sentry Key Antenna Ring which surrounds the ignition lock cylinder. When the ignition is switched on, the Sentry Key Antenna Ring is supplied with power. A data block is transmitted inductively via the Sentry Key Antenna Ring to the SKREEM and then ......
Old Aug 19, 2010 | 04:52 PM
The Kale product is fake. It is bad for the environment.
Blinky Blinkerfluid is real and is biodegradable.
www.blinkerville.com
Ask anybody who has tried it.
It is safe enough to drink
Old Sep 29, 2010 | 11:26 PM
rekcah's Avatar
problem fixed itself.
The only thing I did was seal the gas filler bowl gasket as mentioned in this post
https://www.crossfireforum.org/forum...tml#post491512.
Then I guess what ever had some moisture dried out.
Since I had the interior pulled out to seal the gas filler bowl, I also removed the flaps in the vent that makes that fluttering sound when the subs are thumping.
2004_
Jul 9, 2025 12:39 AM
jgreen
106
Sep 18, 2017 11:46 PM
xfClifford
27
Nov 10, 2015 10:08 PM
KwehCat
Jul 16, 2015 04:48 PM
