Convertible top
Old May 26, 2010 | 07:22 AM
Nightrider's Avatar
Default Convertible top
Anyway of stopping a high pitched whistle coming from the roof to windsheild interface?
Old May 26, 2010 | 09:20 AM
Default Re: Convertible top
Stop driving 125 mph with the top up?
Old May 26, 2010 | 10:11 AM
Nightrider's Avatar
Actually it starts at about 40 mph after 100 it doesn't whistle it sings the words.
Old May 26, 2010 | 11:17 AM
hcarter's Avatar
Try cleaning the gasket on the windshield and see if it helps
Old May 26, 2010 | 01:27 PM
maxcichon's Avatar
I thought I had the same problem. But it was the passenger.
Solution: no more passengers!
Old May 26, 2010 | 01:41 PM
IBLUBYU's Avatar
Lmaorotf ...... Now That"s Funny, Right There ........ I Don't Care What You Say
Old May 26, 2010 | 04:52 PM
Crosscar's Avatar
Try Duct Tape (See attributes below) Looks like it might work up to 100 MPH
Duct tape is a polyethylene, reinforced, multi-purpose pressure sensitive tape with a soft and flexible shell and pressure sensitive adhesive. It is generally silver or black in color but many other colors have recently become available. With a standard width of 1+7⁄8 inches (48 mm), duct tape was originally developed during World War II in 1942 as a water resistant sealing tape for ammunition cases. Permacel, then a division of Johnson & Johnson, used a rubber-based adhesive to help the tape resist water and a fabric backing to add strength. It was also used to repair military equipment quickly, including jeeps, firearms, and aircraft because of these properties.
In military circles, this variant is known as "gun-tape", typically olive-green, and also known for its resistance to oils and greases. It is also called "Riggers Tape", "Hurricane Tape", or "100-mph tape"—a name that comes from the use of a specific variety of duct tape that was supposed to hold up to 100 mph winds. Another version attributes this to the fact that soldiers often refer to something that exceeds expectations as "High Speed."
Just joking, but could not resist the opportunity to share a little Duct Tape humor. We all know it works for everything.
Old May 26, 2010 | 09:26 PM
maxcichon's Avatar
I agree.
Half of the great state of Alabama is held together with that stuff!
Hick weld.
Old May 26, 2010 | 10:03 PM
Grab that black handle thingy and pull it down with a twist and latch it to the windshield frame. The whistle should stop along with that annoying BEEP.
Bruce, it's almost summertime. Why are you driving with the top up?
roadster with a stick
Old May 27, 2010 | 09:26 AM
Nightrider's Avatar
Although I did drive on intertate once in a thunderstorm doing 60-70 (stayed dry too believe it or not) with top down and side windows up...I'd not want to drive topless in rain at lower speeds summer or not.
Old Jun 29, 2010 | 07:20 PM
Nightrider's Avatar
Found the problem...need a solution. The chromish strip across the top of the windsheild is loose. Anyone know the best method of securing it?
Old Jun 29, 2010 | 07:28 PM
Who drives a roadster with the top up anyway?
Old Jun 29, 2010 | 09:25 PM
Nightrider's Avatar
Some onre driving in the rain.
Old Jun 29, 2010 | 10:04 PM
OK, in all seriousness, if that piece is loose, you better either take it off or secure it before it flies off. The trim is expensive to replace. My go-to adhesive is Gorilla Glue. It has never let me down.
Old Jun 30, 2010 | 08:33 AM
Nightrider's Avatar
Thanx Infermo
syfi
Mar 28, 2026 04:14 PM
Osusannah
Feb 12, 2024 01:49 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
