Exterior Light indicator - without reason?
Old Jun 14, 2010 | 02:37 PM
BoeroBoy's Avatar
Default Exterior Light indicator - without reason?
Hi lately my stock 2005 XF Limited roadster (30000 miles) has been showing the exterior light failure dash indicator randomly - though I don't see any bulb problems. All turn signals, brake lights, head lights, hi/low beams work fine. I thought maybe it was the license plate light but the manual does not list it as being covered by the Exterior Light indicator.
Thanks
Old Jun 14, 2010 | 04:03 PM
NAIN's Avatar
Default Re: Exterior Light indicator - without reason?
Did you check the 4 side-markers as well?
Old Jun 14, 2010 | 06:04 PM
maxcichon's Avatar
License plate lamps and all 4 side markers. The license plate lamps have gotten lots of folks here...
Old Jun 14, 2010 | 09:12 PM
BoeroBoy's Avatar
Yep! License plate marker. Talk about a scavenger hunt. They didn't skimp on the details here. Nice.
The sad news - or good news depending on how you look at it - is I ran an OBD scan to see if it could tell me which light was out. Instead I got the big
P0335 - Crankshaft Position Sensor A Circuit Malfunction
No check engine light and still purrs like a kitten. Glad I found it though. Still under extended warranty. Let's see if any dealer will honor it... Thanks guys!
BTW - did search before posting and couldn't find what I needed. I hope this helps someone in the future.
Old Jun 15, 2010 | 07:53 AM
maxcichon's Avatar
Don't feel too bad. The CS pos. sens. is an easy fix. Often, from what I understand, it's the connector to the sensor that's at fault. Poor design or something along those lines.
Glad you found it in your garage and not in some dark parking lot!
Old Jun 18, 2010 | 12:52 AM
srtswizz's Avatar
I had the same problem and I was stumped but then finally realized it was the plate light
Old Jun 18, 2010 | 02:30 AM
MrSix's Avatar
Ha! light went on last night, I did the once around the car with no finds. Light went off a short while later. Next time it goes on I'll know where to check. Crossfire.org rules
Mike
Old Jun 23, 2010 | 07:10 PM
bluecoupe's Avatar
Have the same problem today on the Limited. Just before pulling into the garage the bulb out light came on. I have DRL's so all lights on all the time. I did a walk around and didn't find any lights out. Both license plate lights are working, I changed one about a week ago, all side markers, I pulled the lenses to be sure, positioning lights in the headlamps are OK, high and low beam, all signals work and brake lights work, I checked the fogs but I still get that darn light! I ended up removing my HID's and replaced with stock bulbs just to be sure, but no love light is still on. I tried to check the back-up lights, ignition on run position and car in reverse but no lights. Should they be on or does the car need to be running? Any ideas?
Old Jun 23, 2010 | 08:11 PM
bluecoupe's Avatar
OK problem solved! Back-up light fuse was blown...............any one else find a blown fuse would trigger bulb out indicator? Now I gotta re-install HID's ........what a PITA!!!!
Old Jun 23, 2010 | 09:28 PM
Infinite's Avatar
Turn the key all the way, but dont start it. put it in reverse, lights should come on
2004_
Jul 9, 2025 12:39 AM
northwest_crossfire
May 30, 2016 05:19 PM
stlas69
Sep 3, 2015 10:28 AM
axnguyen
Jul 21, 2015 11:41 AM
skeet370
Jul 18, 2015 01:02 PM
