High Beams
Old Jun 17, 2012 | 03:23 PM
smokey847's Avatar
Default High Beams
Not long ago I replaced my stock low-beams (after one burnt out) with 4300K HIDs. I couldn't be happier with the brightness and performance. Not able to stand the difference between halogens and the HIDs, I replaced my high beams with the same kits as the lows. This was fine when they were on for a while on curvy, country back roads, but in the city when I would need to flash someone to go, etc., the HIDs just do not warm up quick enough to provide and instant burst of light like the halogens.
Therefore, I ordered a highly-recommended pair of Osram Nightbreakers. After installation, I honestly do not see much of a difference in color temperature from the stock bulbs. I am hoping that there is an option I am overlooking--boy do I wish LED technology was advance enough to produce aftermarket LED headlights. Please fill me with suggestions if you have any. Thanks!
Old Jun 17, 2012 | 03:36 PM
maxcichon's Avatar
Default Re: High Beams
I gave up looking, and buying, highbeam replacements to "match" my 5000K HID lows. Snake oil is cheaper.
My collection of "HID Matching" halogens H7's looks like a chess set! I ended up where I started-Sylvania SilverStar Ultras. They don't match, but they are bright...
Old Jun 21, 2012 | 01:53 PM
Erichenderson02's Avatar
I've got 6000K 55w in both highs and lows, and while the high beams don't warm up to full brightness fast enough to rapidly flash my brights, they do provide an initial burst of brightness that's enough of an attention getter (in my opinion).
I'd say the fact that we have separated bulbs is enough of an attention getter even if they aren't that bright.
The only thing I can say is maybe try getting 55w ballasts (if you don't have them already)?
Old Jun 22, 2012 | 01:54 AM
smokey847's Avatar
I'll be honest, I ordered the cheapest pair of HIDs on eBay just to give them a try, Xentec I believe. They haven't given me a problem so I am sticking with them until I will run upon a deal on some Morimotos or a higher-end set of Xenons. I suppose I am quite ignorant about HIDs--would you guess the set I have is 55w or not?
Old Jun 22, 2012 | 02:11 AM
Default
I would bet they're 35w. 55w are harder to come by, and are slightly more expensive usually. For instance, the company I buy them from doesn't even stock 55w in the store anymore. You have to special order them and they ship from china
But I've never had 35w ballasts so I can't really make a comparison of the two.
Do your bulbs flash bright for a second, then dim, and gradually get brighter and brighter? Because thats what mine do
Alternatively, (and not too familiar with these to be honest) but my dad has bulbs that I believe are called HIR's on his truck. Really bright, color temp is similar to halogen though.
Valk
Jul 12, 2021 09:49 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Oct 1, 2015 01:42 AM
ala_xfire
Sep 28, 2015 05:51 PM
Franc Rauscher
Sep 20, 2015 09:35 AM
