Removing the head light assembly
Old Sep 15, 2012 | 01:06 PM
J-Walk's Avatar
Default Removing the head light assembly
My lights are super gunked with crap. It makes the car look used. So I went out and bought the 99.999% Meth alcohol to clean them up. I've removed all of the bolts holding the head lamp assembly in place on the driver side (haven't yet attempted the passenger) but I can't get the thing removed from its spot or the wire harness to detach. Do I have to remove anything else?
Is there a step to step guide on how to do remove the head light assembly? Seems like it'd be a simple thing to do.
Old Sep 15, 2012 | 01:16 PM
turbomar's Avatar
Default Re: Removing the head light assembly
REMOVAL
1. Disconnect the negative battery cable.
2. Remove the headlamp unit upper retaining bolts (1).
3. Open the access panel in the inner fender well.
4. Remove the lower headlamp unit retaining bolts (2).
5. Lift the headlamp unit from the front fascia and disconnect the harness connector and the front position lamp socket.
Old Sep 15, 2012 | 01:28 PM
IBLUBYU's Avatar
Originally Posted by turbomar
REMOVAL
Removing the side marker light will also give some room to work in. I will add this .... eventho you may get the headlamp assembly loose and ready to lift out. It is extremley difficult to work it around so it comes out. Most people have had to remove the front bumper fascia to get it out.l Just sayin ...
Old Sep 15, 2012 | 03:01 PM
1. the wiring connector can be difficult, but persistence will pay off.
2. remove the 2 metal adjusters on the bottom to get a bit more clearance for removal.
3. wait till you can move the assembly around a bit before attempting to remove the running light. ( don't forget to put it back in before securing the unit !!! )
4. upon re-assembly, get the unit in, then start the 2 metal adjusters a couple of turns.
5. secure the unit with the upper 2 bolts.
6. screw the adjusters in until they just touch the lower mounting brackets, then replace the 2 lower bolts.
7. If you haven't already, re-connect the wiring connector.
Old Sep 15, 2012 | 09:50 PM
Remove the grille. Then remove one bolt that holds the front facia to core support. Using a small piece of wood, etc, slightly wedge it under the facia to hold it out of your way. Also use some masking tape to put all around the facia (bumper) to prevent scratches. Here is a pic, the grille was just sitting in there once the light assy was removed.
James
Old Sep 16, 2012 | 12:16 AM
J-Walk's Avatar
Thank you for the replies. I'll be making attempt number 2 on Monday. Can't wait to get these cleaned up. I'll take some before and after shots. They're embarassingly bad.
Old Sep 16, 2012 | 10:13 AM
James
Is that a carpet on the floor?
My wife would not let me park it in the front room. LOL
Old Sep 16, 2012 | 10:37 AM
turbomar's Avatar
Tell her the other crossie guy 's wifes let them! May be she'll change her mind
PNA
Jul 27, 2015 12:28 PM
axnguyen
Jul 21, 2015 11:41 AM
xfireon20z
Jul 20, 2015 04:35 PM
Rus921
Jul 20, 2015 11:09 AM
joethejeweler
Jul 7, 2015 08:58 PM
