Driver side headlight issue with HID
Old 12-30-2012, 09:11 AM
thedirtymex's Avatar
Default Driver side headlight issue with HID
Hi all,
I'm wrapping my roof tomorrow in vinyl. Attempt 2, 1 didnt go so well but I have lots of pics and a little advice to share shortly.
My current issue
I have HID 6000k bulbs installed on my low beams. All is fine until my driver side light goes out. Dash light comes on.
Bought a new kit, swapped out bulbs and ballast no joy. Tested the old bulb and ballast on passenger side and all works.
Im guessing its the wire harness on the hole head light assembly.
Any ideas on what it could be and how to remove the engine coolant tub behind it. Not sure how to tackle that under side push pin bolt thing.
Look forward to sharing my roof adventure and fixing this current issue
Have a safe happy new year
Also if anyone knows where to get cheap NEW head light assemblies for both sides ill be interested in buying. Located in Australia BTW. but still keen.
Old 12-30-2012, 09:22 AM
Default Re: Driver side headlight issue with HID
As to removing the coolant tank : unplug the sensor wire, remove the 2 10mm nuts, then use a large screw driver or small pry bar just above the rubber part of the grommet and leverage while pulling up and rocking the tank. Ain't easy, but can be done. Sometimes the rubber grommet just comes out with the tank.
As to the headlight :
1. new assemblies are hard to find and VERY expensive ( $700-$900 US )
2. I would measure the voltage at the interior plug ( non-HID: connects to bulb, with HID it connects to the HID ballast harness ) and see if you have 12-14.5 volts.
If you see 12-14.5 volts, then ballast/HID bulb issue.
If not then wiring / fuse issue.
( if you don't have a voltage meter, just use an old H7 bulb plugged to the connector )
( if you don't have an old H7 bulb, use the one from the high beam, but DON'T TOUCH THE BULB WITH YOUR FINGERS - use a clean cloth or gloves )
Old 12-30-2012, 09:23 AM
holy ****, i bet its the fuse.
tomorrow im buying a volt meter and a fuse set and giving it ago.
i love this community.
Old 12-30-2012, 09:39 AM
You should look at fuse 6 or 8 inside the panel at the end of the dash on the driver's side.
( not sure which one, since yours is RHD - anyway - look in your owners manual index for 'fuses' )
What's a 'dirty Mexican' doing in Australia anyway ?
Old 12-30-2012, 09:49 AM
hahaha,
an old nick name, im actually Chilean.
an old boss was convinced that chile was near mexico. The same night I pulled a couple girls in his company. Hence... the dirty mex.
Old 12-30-2012, 10:17 AM
IBLUBYU's Avatar
I had success with this removal, by spraying some WD40 onto the tank barb and grommet. Let it soak for 15 minuites, sprayed again, then just pulled up (it took some force), with slight rocking and it popped out. I applied silicone gel to the grommet when re-installing, and it just popped back in.
Actually, I resisted using a pry bar for fear of breaking something, altho this might work also, with care.
Old 12-30-2012, 10:51 AM
Originally Posted by IBLUBYU
Actually, I resisted using a pry bar for fear of breaking something, altho this might work also, with care. [/SIZE] [/SIZE][/FONT][/SIZE][/COLOR]
I too resisted the pry bar the first time I attempted to remove it, but I got pissed off and used it.
Old 12-30-2012, 11:36 PM
It was the fuse. Cant bloody believe it.
$80+ spent on a $2 fix. haha
But I found out im missing the clip from the passenger side bulb. When they installed the HID bulb they used a black putty to seal it in. sigh
Wasnt able to remove the coolant tank. Will try the WD40 trick. Still have a day before I need to drive.
Cant wrap either. Bloody raining ay.
Thanks Brothers
BrenLW
08-05-2015 04:53 AM
michaelcycle58
07-28-2015 08:12 PM
waldig
07-20-2015 08:10 AM
ZX2 Nick
07-15-2015 08:49 PM
66L72M21
07-15-2015 04:23 PM
Quick Reply: Driver side headlight issue with HID
