Both headlights out, several posts but no answers!
Old Apr 8, 2013 | 04:43 PM
boucherh's Avatar
Default Both headlights out, several posts but no answers!
Hi Guys,
I see people have posted several times inquiring about both low beams being out but I have yet to find an answer to the question. My high beams work, fuses are both ok, BRAND NEW bulbs (less than a month old). Any ideas? Someone suggested some sort of switch. Where is this located and is it something I can check myself to see if its bad? Thanks!
Old Apr 10, 2013 | 12:58 PM
Jamerian's Avatar
Default Re: Both headlights out, several posts but no answers!
Check for power on a gray/yellow or vice versa on the backside of the illumination control module (headlight switch) when you switch them on. Very vague..ill give u the actual pin in a few hours when im back ar work
Old Apr 10, 2013 | 01:54 PM
Jamerian's Avatar
My mistake. Check for power on a white/yellow wire when the headlights are turned on. The wire is in a 10 pin connector on the back of the switch in between a black/white ( with little blue sploches ) wire and a darkgrn/white wire. Also check the the same power on a tellow wire and a yellow/black. These 2 wires are in a 21 pin connector and are 2 pins away from eachother. Theyre fused by fuse 6 and 8 respectively.
Old Apr 10, 2013 | 08:59 PM
Indelibility's Avatar
Mine did that 2 months ago. Both low beams burnt out at the exact same time. Bought a new pair and have been peachy since.
Try putting the high beam bulb in the low beam socket since they're both H7. If it works, they just went bad. If not...
Old Apr 10, 2013 | 11:27 PM
Jamerian's Avatar
Originally Posted by boucherh
hi guys,
brand new bulbs (less than a month old). !
Old Apr 10, 2013 | 11:30 PM
Adrian_X's Avatar
My advice if you can afford to spend 150 on HIDs from theretrofitsource.com, do it. It'll literally be the best investment you will ever do on this car in terms of lighting.
I've had multiple lowbeam bulbs go out on me, and after the 3rd one, I said screw it and went with HIDs on it. It's about 3 times brighter than even the silvestar ultras, and they will last around 5 years on one set of bulbs.
pioneer4x4
Mar 25, 2019 10:35 AM
gp1200x
Dec 6, 2015 12:59 PM
waldig
Sep 2, 2015 11:02 AM
blacktouring
Jul 31, 2015 11:50 AM
waldig
Jul 15, 2015 02:05 PM
