Rear winged emblem
Old Apr 1, 2015 | 07:10 AM
Sterling57's Avatar
Default Rear winged emblem
Hello, has anyone ever removed the rear winged emblem, if so how , replacing a damaged one and replacing new from eBay and re badging at the same time, thanks
Old Apr 1, 2015 | 05:55 PM
Trenzman's Avatar
Default Re: Rear winged emblem
In the rear one i believe you have to reove the plastic from under the trunk lid to get to the bolts holding the emblem
Old Apr 1, 2015 | 10:34 PM
yellowhammer's Avatar
Just replaced my front and rear emblems. Drill small holes 1/8" diameter vertically 5 or 6 in the center from top to bottom. Not to deep just barely through the clear top dome maybe 1/16" to 1/8" take your time be careful not to deep. Then I took some very small sharp diaginal wire cutters and cut between the holes until you can grab it and twist easy and pull the 2 halves out one at a time. Just dont drill to deep it was a very easy job to do. Hub caps too, replaced all 6 with new crossfire emblems. Looks great.
Old Apr 1, 2015 | 10:46 PM
Sorry I also took the rear wing emblem off because the original double sided tape had partcialy come loose no bolts just double sided tape. Used the 3M automotive double sided tape on the wing emblem also on my truck badges 3 years ago after new paint job still tight as new. Use dental floss to cut the emblems off, then clean very well with alcohol to remove any residual tape or glue. Not that hard just get it clean.
Old Apr 3, 2015 | 12:11 PM
Sterling57's Avatar
Ok did look on YouTube and found how some people removed emblems , just wanted to see if any body did our emblems , thanks.
Old Apr 3, 2015 | 09:07 PM
I found the info here under search don't really remember where, description only no pictures.
No bolts or push on clips under rear wing emblem double sided tape removed only because loose.
Use dental floss to remove rear wing emblem from trunk/hatch lid.
Use drill method to remove badges from wing emblems don't need remove wing emblem form car.
Front wing emblem has push on clips to hood.
Front and rear badges no bolts or clips just silicone.
Hub cap badges silicone only removed with drill method.
Old Apr 3, 2015 | 11:49 PM
JEFASOLD's Avatar
Also has double sided tape at each end.
blackpepper
Dec 18, 2021 06:17 PM
Jonacross
20
Jul 17, 2017 11:19 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Idrenak
Sep 19, 2015 08:17 PM
steps
Sep 12, 2015 09:23 PM
