Door bottom rusted through - repair or need to replace full door?
Old Dec 23, 2020 | 05:59 PM
VBVASmith's Avatar
Default Door bottom rusted through - repair or need to replace full door?
2006 Crossfire Roadster with only 12800 miles. Bottom of driver door 95% rust through. Right door not as bad but definitely rusting.
CAN THE RUSTED AREA ACROSS MAJORITY OF DOOR BOTTOM BE REPAIRED (remember there is also a gasket at bottom to keep water out.) OR does full door need to be replaced? OBVIOUSLY, there must be some drain holes that must be plugged. What a frustration. And cost/inconvenience. Thanks for advice.
Old Dec 23, 2020 | 06:46 PM
Default Re: Door bottom rusted through - repair or need to replace full door?
Unfortunately someone who had your Crossfire didn't see this thread
>>>WOW ... stop the rust while you can<<<
POST #1 -- PHOTOS
Old Dec 24, 2020 | 05:03 PM
twanger's Avatar
Of course it can be repaired , but how and cost depends on extent of rust .
Old Dec 24, 2020 | 05:26 PM
Rain draining down the rear windows when the car is stationary runs forward and is then channeled into a funnel moulded into the rear of the front door seal. This water then runs down inside the front door and out some drainage holes.
I cleaned out the doors bottoms of a layer of dirt and dust and sprayed a rust preventative on door sides, bottoms and the seams between them.
Old Dec 26, 2020 | 11:30 AM
I first learned of this issue in 2009, here on the forum, when I bought my first Crossfire.
To my mind, it's a design flaw, and even if it isn't, could they not have taken better steps against this in production?
The Germans don't build any better cars than we do. Dumbass design, lousy production standards and union made - a bad recipe in any country.
dayjor
May 24, 2013 11:54 AM
ouncolao
Mar 19, 2008 12:47 PM
Steven's Toys
Jan 16, 2008 03:50 PM
Rabidraider
Feb 16, 2006 08:08 PM
Ronman
18
Apr 7, 2004 11:04 AM
