High beams not working but high beams indictor comes on
Old Feb 26, 2021 | 06:15 AM
THE CUHHFIRE's Avatar
Default High beams not working but high beams indictor comes on
Well I had my 04 Crossfire for 1 and a half now but after some time of use the high beams wouldn’t turn on but the indicator turns on whenever I take out the bulbs but when I put new bulbs the indicator won’t come on unless there’s no bulbs connected which could be an electrical problem but I will double check fuses but any idea what it could be ?
Old Oct 14, 2021 | 01:35 AM
SD Crossfire's Avatar
Default Re: High beams not working but high beams indictor comes on
Did you find out a solution to this? I just got my 2004 Coupe, just found out the high beams don't work, but my indicators on the dash does.
Old Oct 14, 2021 | 07:42 AM
no I haven’t figured that out yet but seems no on else has the problem if I find a solution I’ll be back with an answer
Old Oct 14, 2021 | 09:01 AM
DTMenace's Avatar
GUYS
Since this forum has been up and running for 18+ years, this may have been discussed at least once or twice in the past 18 years?
How about using the SEARCH button at the top of the front page and entering "High Beams" and hit the GO button.
You would be
surprised at what you can find in the archives....
Dennis
DTMenace
Old Oct 14, 2021 | 12:20 PM
nemiro's Avatar
Is the car running when you are testing this? Reason I ask is that they won't turn on if it is not running.
Old Oct 14, 2021 | 01:25 PM
They turn on but will not flash.
Old Oct 14, 2021 | 02:45 PM
nemiro's Avatar
Ah! I stand corrected.
Old Oct 14, 2021 | 02:56 PM
I could not say what was correct, so I went to the garage.At least I know now, until I forget of course.
Old Oct 14, 2021 | 11:18 PM
tripster930's Avatar
may be the switch, sometimes the contacts go bad on it
Old Oct 15, 2021 | 10:34 AM
GUYS
You would be surprised at what you can find in the archives....
Yes, that is what I did, I searched and found no other thread that matched my high-beam issue exactly except this one. Luckily this person had the exact same issue (high beams don't function but the indicator does) and last posted on this thread 8 months ago, and I decided to reply back to him and see if he found a resolution.
He replied back and we are continuing the conversation. Which I think is better than create a new thread?
Old Oct 15, 2021 | 11:32 AM
You say indicators but there is only one blue indicator for the high beam.
Maybe the bulbs are NFG, I had headlight bulbs on both sides blow in the space of a week.
Maybe the fuses are blown.
‘Look for the simple answer first’ is a good motto.
MAYAman
Dec 13, 2016 05:42 AM
IGot2P
Apr 21, 2015 08:45 AM
Furgal
Jan 31, 2014 04:29 PM
TX_xfire
Aug 21, 2009 03:15 PM
sparks81
Nov 12, 2007 08:51 AM
