blinker will not turn off
Old Jul 28, 2021 | 04:37 PM
Swimman1's Avatar
Default blinker will not turn off
My blinkers stay on any time the battery is connected on the right side only???HELP
Old Jul 29, 2021 | 09:35 AM
Doc78's Avatar
Default Re: blinker will not turn off
I've been looking for you in the service manual. Page 8L-18 starts the lamp diagnostics.
https://www.crossfireforum.org/forum...ollection.html
The manual is available for download from the link above.
Old Jul 29, 2021 | 12:13 PM
magredvet's Avatar
Check that your indicator stalk is not left to engage the RH blinker when you turn the car off, as this will set the parking lights on that side..it's a European thing
Old Jul 29, 2021 | 07:26 PM
When you say 'blinkers' do you mean they are 'flashing like your turning'? Need a little more information... Also, is your headlight switch dial indicator straight up? There is two positions that allow you to light up the right OR left side 'running lights(?)' when you 'park' the car (like when your on the side of the road and such). Get back with us on some more information about your 'blinkers' statement. Good luck!
Old Jul 30, 2021 | 08:52 AM
Swimman1's Avatar
they just stay on ( not blinking). ? Did the switch thing and it is where it belongs. thanks. Did you ever have this problem ?
Old Jul 30, 2021 | 05:09 PM
Hello, no never had this problem. Does the switch (light switch) work normally (except for this problem)? Far left rotation left side front and read park lamps, second position FROM left (right side marker lights), Center position all lights should be off but..... 4th position from left & turning switch to right (all park and marker lamps lit), and finally fifth position from left all lamps (including fog and high beams if activated)? I'll await your reply in case I didn't make myself clear. Thanks!
CyberCG
Apr 17, 2021 03:10 PM
D16
Mar 8, 2018 09:39 AM
dirkbaski1
North America
Oct 30, 2014 12:05 PM
Jackerman
Apr 6, 2012 11:52 AM
rakoom2002
Oct 29, 2006 12:10 AM
