Third brake light
Old Aug 26, 2021 | 10:41 PM
Ervinm's Avatar
Default Third brake light
Need information on how to remove panel to add blinking led light unit.
Old Aug 27, 2021 | 12:32 AM
Default Re: Third brake light
coupe or roadster ?
Old Aug 27, 2021 | 11:13 AM
Ervinm's Avatar
Sorry for not stating, it is a 2006 coupe. I resently purchased, it is my first Crossfire so I am fairly ignorant on does and don'ts of my car. Thanks for the response.
I do not need to replace the light, I just want to get into it to add a flashing module.
Old Aug 27, 2021 | 05:19 PM
I would try U-tube?
Old Aug 27, 2021 | 06:55 PM
There is a tutorial installing a module that fit inside the top of the hatch area, I have it here to upload BUT seems the forum isn't allowing the upload???. I don't know if it is still in the document collection here in the forum. Good luck!
Old Sep 28, 2021 | 03:59 PM
mrradio's Avatar
My two cents for a malfunctioning third brake light. Car would not pass a safety check here in Ontario Canada with non operational third brake light. Chrysler says part is obsolete. Mechanic referred me to a place in the US. I said I would have a look myself thank you very much. Removed the trim nearest the latch first (one hidden torx screw) . That exposes two torx screws for the trim covering the third brake light. Pull out tabs with care. I confirmed that the 12V was active at the connector when the brake pedal was applied.
The LED unit itself comes out by loosening three phillips screws and one electrical connector. You can take this unit apart by prying gently at the tabs.. The circuit board comes out as well, gently prying it out (more plastic tabs). Mine did not break. The board is marked with a plus sign to tell you which is the 12V hot side for testing. In my case I had a good look at the connections and could not find any bad solder. It was unlikely that ALL of the LEDs had gone defective, so I concentrated on the resistors and the eventual CULPRIT, a single little black diode (1N4004). It should conduct in one direction and it did not, so was deemed defective. I found a similar one in the junk drawer and soldered it in. Voila, success. Anyone can do this. If you don't have a diode try Radio shack. I went back to the mechanic two hours later and he issued the certificate.
Old Sep 29, 2021 | 07:31 PM
I believe the OP only wanted to install a little box that flashes the third brake light. While it is nice to know some can fix their own malfunctioning third brake light (instead of sending it into the source found here in the forum document collection), all the OP wanted to do was get to a location where he could mount the module.
Old Sep 29, 2021 | 07:59 PM
Ervinm's Avatar
Thanks for the responses, I am only going to install a blinker. I appreciate the information I needed to get to the wiring and the color coding for the wires. Thanks Guys.
Old Sep 29, 2021 | 08:23 PM
mrradio's Avatar
Quite right. Posted to the wrong place. Apologies.
Depending on the size of the module, it would fit nicely under the third brake light cover. Electrical connection wires are long enough to put the flashing module in series with the third brake light. Ps. The LED assembly works directly from 12 volts on my 04 limited .
Old Sep 29, 2021 | 11:41 PM
Here is GGs post on how to install.
Wabinila
Oct 15, 2014 08:23 AM
speedway--Z
Feb 18, 2014 06:50 AM
bfffk
Sep 28, 2010 08:38 PM
Larrym
Mar 22, 2009 04:17 PM
srt-6 rag top
Sep 24, 2008 01:36 PM
