blinker problem
Old Nov 15, 2024 | 05:02 PM
blue road runner's Avatar
Default blinker problem
I have a blinker problem. When I lock my SRT6 (using my key fob) the normal exterior lights flash showing the doors/trunk lock and then all 4 blinkers start to flash. Two ways I have found to stop the blinkers from flashing is to
---disconnect the neg battery cable and the lock my car using the door key.
---reconnect the battery cable and then use the key fob to lock the car.
Don't know if this makes any difference but seems to only happen after I have driven my car. Would appreciate any thoughts you might have about what might be the cause
Old Nov 15, 2024 | 05:40 PM
Default Re: blinker problem
I would disconnect the alarm siren under the cowl in front of the windshield. It is probably going bad.
Old Nov 16, 2024 | 12:04 PM
NeedsWings's Avatar
probably already bad, internal siren battery ruptures and the battery acid spills onto the siren circuit board causing all sorts of electrical gremlins in the car, replace or just unplug the siren and go without.
Old Nov 16, 2024 | 01:21 PM
Thank you for your help. I will disconnect the siren on my car.
Jerry
Brady517
Jul 28, 2021 01:18 PM
dsdesigns
Feb 6, 2014 08:05 AM
jacobcmiller
Apr 25, 2012 02:18 PM
mdaniels4
May 21, 2009 04:41 PM
an0nym0u5
Jul 22, 2008 05:56 AM
