Trunk light
Old May 6, 2025 | 04:52 PM
Default Trunk light
Where is the trunk light switch on a roadster and how can you check that the light is out when the deck is closed?
Thanks
Old May 6, 2025 | 05:10 PM
dcskmail's Avatar
Default Re: Trunk light
I believe it built into the trunk latch, put your phone on video record, place it in the trunk camera lens side up while recording and close it ,wait awhile then watch the video to see if it's gone out
Old May 6, 2025 | 05:13 PM
Thanks, I guess there is no way to verify it is out then?
Old May 6, 2025 | 09:39 PM
No way to know if that light is off once the trunk is closed
Because of this I have my bulb removed from the trunk light and the glove box
I don't need the hassle of a battery drain for a trunk light or glove box light that stays on !!!
Old May 7, 2025 | 12:08 AM
Hindin's Avatar
Simple: Put your iPhone/cell phone on video hit record button and close the trunk. Wait 60 seconds open the trunk and see it turned into the new iPhone 16 plus. Or if the light went out.
Old May 7, 2025 | 11:05 AM
The rule is:
2005-2006: If the interior light goes out, the trunk light does too. THey are wired together.
2007-2008: The Cellphone trick is the only way to KNOW it is out, as there are two circuits in the 07-08s, one for interior "dome" light and one for the trunk light.
Old May 7, 2025 | 11:36 AM
Thanks to all !
Old May 7, 2025 | 11:45 AM
Pizzaguy,
I assume that means that on the 05 and 06 , if the trunk is open the interior lights are also on?
Old May 7, 2025 | 03:28 PM
Originally Posted by ZERACER
Pizzaguy,
IT does, try it! In the diagram, "Cargo LIght" is the trunk light.
Old May 7, 2025 | 04:23 PM
Thank you sir, I had looked at the diagram but didn't understand the trigger.
seasidenj
Aug 6, 2023 10:44 PM
frankthetank81
May 10, 2021 03:49 PM
Petersrt6
Dec 3, 2019 12:08 PM
Blackktieguy
Apr 3, 2016 11:14 PM
popeye
Jul 9, 2008 01:07 PM
