Brake light issue
Old Jan 10, 2026 | 11:51 PM
keithdavis2092's Avatar
Default Brake light issue
I have a 2004 Chrysler Crossfire base
The driver's side brake light is illuminated even when off and all doors closed. I removed both harnesses to the brake switch and the light would still stay illuminated. I then plugged them back in. I noticed the issue doesn't persist when the car is on. When the car is cranked, the light functions as intended when the dial for the lights is in the off position( no lights on when car is on and dial is to off).
I removed the number 10 fuse which is for the left lamp and the light immediately turns off when the car is off. I replaced it with the spare to check if it's some kind of fuse issue, but with the replacement fuse in the light immediately turns on with the car off.
I'm completely confused. The only maintenance I've done recently that is electrical is replacing the alternator.
***ADDITIONAL INFO*** The passenger side park light isn't doing this, only the driver side!?!?
Old Jan 11, 2026 | 06:10 AM
DeKalb's Avatar
Default Re: Brake light issue
What position is your headlight switch in? The OFF position is in the middle of the switch, not all the way to the left.
Old Jan 11, 2026 | 06:31 AM
lol it was all the way to the left
Old Jan 11, 2026 | 06:32 AM
I will test it now. Had too much going on in life so think I had a mental breakdown. Appreciate the info
Old Jan 11, 2026 | 06:49 PM
it worked, thank you!!!
Old Jan 11, 2026 | 09:38 PM
Thank you for the update. We appreciate it when people don't leave us hanging.
Old Jan 11, 2026 | 09:52 PM
The infamous parking lights on the Crossfire.
BP11
Sep 29, 2014 04:09 PM
Erichenderson02
Jul 12, 2011 01:51 PM
dkendall
Aug 19, 2010 10:02 AM
Don Hiltz
Jul 5, 2009 03:13 PM
Don Hiltz
May 2, 2009 11:50 PM
