parking light
Old Sep 5, 2009 | 05:49 PM
annie's Avatar
Default parking light
Hi guys, do you have any tips how to change a parking light?
Old Sep 5, 2009 | 06:41 PM
maxcichon's Avatar
Default Re: parking light
I presume you are referring to the "eyebrow" lights in the upper, outsides of the heaglight housings? They can be a bear.
If you have an SRT, you must remove the Radiator Fan Control unit on the drivers' side tire well to gain clearance for your hands. Otherwise:
Using a pair of hemostats or neednose pliers, you must turn the rubber bulb holder 90 degrees counter-clockwise and then pull straight back. I have found it necessary to use the tip of one finger (from the bottom) and a flat blade screwdriver (from the top), pushing in opposite directions, to accomplish this. It truely sucks. Once done-lubricate the orings before re-assembly. Makes it much easier and aids in removal next time.
Old Sep 5, 2009 | 07:58 PM
I put amber colored 194s in mine. It is not an easy job. As Max said, help from different tools is a good idea.
James
Old Sep 6, 2009 | 07:33 AM
maxcichon's Avatar
Since James brought it up-LED's are a choice of many here. They last forever and you will not need to replace them again!
I used these:
2x Super White 3 Chips 5 SMD LED Light Bulb 194 W5W T10:eBay Motors (item 250488926917 end time Sep-06-09 20:47:00 PDT)
Old Sep 6, 2009 | 09:27 AM
I just try not to drive mine at night.....OK, I'll shut up now...
Old Sep 13, 2009 | 12:17 AM
annie's Avatar
thank you for your replies and answers, i have come to relize that replacing a light in this car is going to be a pain since there is no room...
my friend has small hands ans she was able to put her hand through the fender ..just above the tire and i think that is the only way to do it..otherwise you will damage something.
gp1200x
Dec 6, 2015 12:59 PM
velociabstract
15
Sep 7, 2015 03:43 PM
toob
Aug 19, 2015 07:31 AM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
Bill F
South Forum
Aug 7, 2015 11:16 AM
