Fuel
Old Jul 25, 2010 | 10:20 AM
Barb's Avatar
Default Fuel
Can regular fuel be used or is there a definite need for preimum? I also drive a benz in which i have always used premium however wondering if regular is ok for the Crossfire? What is everyones opinion?
Old Jul 25, 2010 | 10:27 AM
+fireamx's Avatar
Default Re: Fuel
Very popular question.
https://www.crossfireforum.org/forum...archid=1140126
Old Jul 25, 2010 | 10:28 AM
IBLUBYU's Avatar
Default Re: Fuel
Premium 93 octane .... of course regular can be used in an "emergency only" basis. Like, if you run out of gas and need to get to a station. Only use "fluids" recomended in your manual......
Old Jul 25, 2010 | 10:35 AM
Erzer's Avatar
Default Re: Fuel
Welcome to the forum. As pointed out it was and still becomes a popular question; follow the link that was provided and you can get more info.
I know when I bought mine the dealers rep said you don't have to use premium but I decided to call their maint shop as well as a couple of others and they all said you can, but don't do it or you'll be in here on a regular basis clearing out error codes etc.
Old Jul 25, 2010 | 10:40 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Fuel
Avoid Canadian fuels with the additive MMT
Default Re: Fuel
Old Jul 25, 2010 | 11:34 AM
Default Re: Fuel
its all here:
CanadianDriver The Environment Auto Tech: MMT: the controversy over this fuel additive continues
and from the 2005 Owners Manual :
MMT in Gasoline
MMT is a manganese containing metallic additive that is
blended into some gasolines to increase the octane number.
Gasolines blended with MMT offer no performance
advantage beyond gasolines of the same octane number
without MMT. Gasolines blended with MMT have shown
to reduce spark plug life and reduce emission system
performance in some vehicles. DaimlerChrysler Corporation
recommends using gasolines without MMT. Since
the MMT content of gasoline may not be indicated on the
pump, you should ask your gasoline retailer whether or
not his/her gasoline contains MMT.
MMT is prohibited in both Federal and California reformulated
gasolines.
In Canada, MMT can be used at levels higher than those
allowed in the United States. For this reason, it is even
more important to look for gasolines without MMT in
Canada.
STARTING AND OPERATING 165
Old Jul 25, 2010 | 12:47 PM
Default Re: Fuel
Why burn regular gas? The cost savings (at least here in Georiga) are less than 30 cents per gallon.
So, for under $3.50 per fill up, I use what they tell me to use. THINK of how many tanks of gas at $3.50 per tank you'd have to burn to save the cost of repairs (or even clearing of codes) to make up for it.
The fuel filler door tells you PREMIUM ONLY. That is not a recommendation, its an instruction.
(You asked for everyone's opinion - you now have mine. )
Old Jul 25, 2010 | 02:10 PM
Default Re: Fuel
This was dated 2004, a bit old but still relevant. I would assume the last two have stopped using it by now. It would appear MMT is a non issue these days.
"According to the Sierra Club of Canada, so far Shell Canada, Irving, Imperial, Petro Canada, Sunoco, and Ultramar have stopped using MMT. Only Co-Op and Husky are still adding the controversial neuro-toxic anti-knock agent to gas."
roar
Jun 15, 2022 11:46 AM
rampntlion
21
Feb 11, 2019 08:18 AM
berklund
15
Sep 19, 2016 03:14 PM
RacerXofFL
Sep 15, 2015 05:00 PM
81's
Sep 13, 2015 04:34 PM
