door and trunk not locking with fob
Old Oct 6, 2022 | 01:57 PM
Denny White's Avatar
Angry door and trunk not locking with fob
2005 Coupe - when using fob pass door and trunk do not lock. Driver door OK.
Old Oct 6, 2022 | 02:10 PM
zip439's Avatar
Default Re: door and trunk not locking with fob
So the FOB works okay for the drivers door, but not the other two???
You have a pressure leak/vacuum leak in the system; the pump is located under the hatch passenger side.
Old Oct 6, 2022 | 04:55 PM
Does the fuel cap cover lock? It is teed off the passenger door lock, so it should not lock.
The common area for the air line to break is in the corrugated tube at the top of the hatch on the passenger side or the similar hose at the bottom of the passenger door.
It can be fixed in these areas using a larger hose over the yellow hose. Do not use PVC hose use urethane hose as PVC cracks after time.
If it is a hose you might hear a hissing sound.
Old Oct 11, 2022 | 11:52 PM
Yes, fuel door does lock??? I pulled off the right side trunk panel and saw where one of the air lines split thinking it went to fuel door or trunk.
Old Oct 12, 2022 | 11:14 AM
No matter where the line goes, fix it and you'll probably have working 'everything' locked/unlocked again. There is a threshold whereas if there is a leak somewhere, the system is trying to work, but lack of a sealed system will result in strange behavior (depending on where and how bad the leak is). There are some posts on how to fix specific areas of leaking air lines, just use good common sense and you should be fine. Good luck!
Pierantonio
Apr 25, 2016 08:56 AM
Spudracer
Nov 3, 2011 02:48 PM
WindRestrictor
Apr 6, 2011 02:12 PM
Erzer
Feb 27, 2009 05:59 PM
apkano
Oct 1, 2007 03:57 PM
