Center dash removal (aluminum pieces)
Did a search ...?
can anbody advise me on removing the 11 pieces to the center
dash area (the aluminum looking pieces).
IE do you use a license to pry them up / off ?? are there clips
holding them or are they just press fit ?
Thanks,
Ken
Thanks,
Ken
I am going through the same thing. I found one post that said once you remove the radio (needs special tool) that there are screws on the panels and then they pop out. I haven't tried it.
Please let us know what you discover.
I haven't done this yet myself but have read the instructions several times from Mitchell Automotive (requires account with them) to familiarize myself for my gauge install.
"I haven't done this yet myself but have read the instructions several times from Mitchell Automotive (requires account with them) to familiarize myself for my gauge install."
Any chance you could publish some more of that interior removal stuff without going to jail?
I was able to attach the file above. (It is actually 3 sections for removing the lower instrument panel, console cover & then the center console itself). The instructions for removing the portion between the seats are attached in another thread...so it wouldn't allow me to attach it again here.
Originally Posted by danimal
For those that have asked, here are the instructions from the service manual. Hope they help.
can you send some of your sunshine up here ...(Seattle)
Thank you, Danimal. I need to change out a couple of the pieces on the center console, but couldn't figure out what was holding them.
does anyone know how to remove the "curved" plastic piece that goes over the instrument panel? I'm not even sure if I'm describing it correctly. goes to show my lack of knowledge with cars. I'm trying to take the plastic curve piece that is attached to the dash. thanks in advance for the information...
LE Cross
Oct 17, 2016 06:35 AM
