Peeling Console
Old Mar 21, 2008 | 10:46 AM
Crossfire1957's Avatar
Default Peeling Console
Checked on any threads about the problem I am having. I have a 04 Limited coupe. Interior is black. I have around the Emergency Brak noticed theat the console is peeling with a rubber type substance. It is getting worse and spreading, Anybody else have this problem.
Old Mar 21, 2008 | 10:50 AM
robby363's Avatar
Default Re: Peeling Console
Check here it looks like your not the only one.https://www.crossfireforum.org/forum...earchid=385669
Old Mar 21, 2008 | 01:40 PM
ravenous's Avatar
Originally Posted by robby363
Check here it looks like your not the only one.https://www.crossfireforum.org/forum...earchid=385510
Error- won't display page
Old Mar 21, 2008 | 01:46 PM
robby363's Avatar
Try this one,https://www.crossfireforum.org/forum...earchid=385669 I don't know why it's not working.
Old Mar 21, 2008 | 02:03 PM
MAYAman's Avatar
Does any body have any pictures of this? I mean for being so prevelent there are zero pictures. I have not had this problem but would love to know what to look for.
thanks
Old Mar 21, 2008 | 02:58 PM
BRappaport's Avatar
thanks
I would also be very interested in some pics of different areas that are peeling. Thanks
Old Mar 21, 2008 | 03:51 PM
CoupeGirl's Avatar
There is a spray pain tfor the inside I have the ceader and did it near the keyhole you cant tell at all...
Old Mar 21, 2008 | 07:51 PM
RMADERMAN's Avatar
If you XF is still under warranty, the dealer will/should replace the center console. They are doing it on my daughter's SRT next week. Had ordered the complete console ,but only received the portion by the ermergency break. The front part was received, but in black. It was supposed to be red/cedar. The color change is a different story.
Old Mar 24, 2008 | 07:34 AM
Cool Re: Peeling Console
I took some pictures to post on here but sorry S****Y Camera. My daughter has a good one and she is coming this weekend and said she could take some for me and I will try to get them on here. I just talked to my Service manager and they took pictures to send to chrysler, he was of the understanding they would replace the console. it looks like the seat belt buckle is the problem. That is the area it is peeling. Around the emergency brake. I have noticed some pin holes coming on the other side and just a matter of time before it starts to peel worse. And of course this is the first place that I look when I get inside and it just irritates me to no end. My car was stored by the orginal owner for about two years, in a garage at his house, I am not sure if heat could have been the initial problem, Let all of you know how things turn out with Chrysler. Thanks for the comments everybody, it helps.
Old Mar 24, 2008 | 03:08 PM
Thumbs up Re: Peeling Console
Just talked to my Service Manager, Chrysler okd the replacement for the console, ordered and will be here by the end of the month.
Old Mar 26, 2008 | 04:24 PM
Crossfire Trail's Avatar
Just to let you know, it seems to be a common problem with some cars. I suspect that a harsh chemical cleaner is the culprit. I drove a dealer's white roadster, a few weeks ago, it had a black interior and it was peeeling all over the place, it was disgusting and they were asking $20,000 for this piece of crap. I told them of the problems that I encountered and I got a letter from one of the owners of the dealership ( a Ford Dealer) very well known. I answered the letter and told them in no uncertain terms that this was not expected, that whoever detailed the car should have mentioned it. A poor job and as poor a presentation as I have seen. My car looked and ran a hundred times better.
Old May 8, 2008 | 05:25 PM
nox1s's Avatar
Old thread.. but did anyone happen to taken pictures? I saw the one with CoupeGirl but that wasn't really clear... I think mine is peeling but i'm not sure..?!
Old Jun 8, 2008 | 11:51 PM
golfdude's Avatar
I'll take pictures of my peeling and shriviling interior tomorrow soon for all to see as well.
Old Jun 9, 2008 | 07:20 AM
Golfdude, it certainly should not do that. I don't know what year your car is but if it's still under warranty, I'd get my butt over to the dealer's and have them replace the whole thing, if need be. What kind of chemicals are you using to clean and prepare your interior? Although it shoudn't do that, it could be corrosion. Any cleaner containing a bleach should be avoided. Silicones are OK and widely used. But, they too can cause a problem if the wrong propellant is used. If the can gets cold and it's a hot day, a problem could arise.
Back when I drove the car in my original post, I was taken aback by how terrible the peeling was in that car. I also know that they (at the factory) spray a rubberized coating on the plastic pieces that form the interior. It may be that it they were not cleaned properly prior to the spray process.
Old Jun 9, 2008 | 09:28 AM
golfdude's Avatar
PICS!!
I'm just surprised at how fragile the interior panels are. The same products I use on this car I use on my client's car, and this doesn't happen. Take a look:
Fossil-edition passanger arm rest:
The peeling pics here are very difficult to capture. But an accurate way to describe them is the fact that it looks like dead skin peeling when you get a sunburn:
Old Jun 13, 2008 | 08:51 PM
nox1s's Avatar
Would you consider this peeling, or "normal wear and tear"
I'll give ya one guess which one my dealer picked!!
Old Jun 13, 2008 | 09:12 PM
Violenteer's Avatar
this is the same problem my car has, and around the key hole, and my vehicle has only done 10, 000 km.
i am gathering at this stage that the easiest route, if the dealer does not come through, or you are out of warranty, is to repaint.
i am on the verge of either a) repaint b) cover in suede or leather.
Old Jun 13, 2008 | 09:15 PM
nox1s's Avatar
I had talked to another Crossfire owner around here that has the same problem.. and his WAS replaced under Warranty.. THe problem is that the dealer was ~1 hr away and honestly it would be a LOT of work to go to that particular dealer to get this replaced.. So I bought a whole new one..
I'd keep trying to find a dealer that WILL replace it.
Mackel
Oct 16, 2015 09:03 AM
nataliefs
Oct 5, 2015 01:03 PM
RacerXofFL
Sep 15, 2015 05:00 PM
55chevy
Sep 13, 2015 07:38 PM
davidc90
Sep 6, 2015 10:37 PM
